Question about Philco (R) 841.205 CD Shelf System
Turn Table stopped?
Hello! I bought this player this morning used and it worked perfectly when I brought it home. I only played one record through on it and when the record ended I heard the table stop, so I went over and turned the system off to change records and when I turned it back on the table wouldn't turn! all other functions (cd and cassette) still work just fine but even when I reattach the belt nothing moves! Is there something I may be missing to replace this? I did not drop it/jolt any of the parts between the two records so I just don't understand why one would have played and the next not??
Thanks so much for your help-
Whitney
    Genius:
  • 3,422 Answers
This is for ANY belt driven turntable.
The belt is usually directly beneath the platter (the part your record sits on). If you lift this up and out of the way there are two wheels, a small one from the motor ( less than 1" in diameter) and a larger one (usually more than double the size of the small one). The belt goes on around both of these. So the setup looks like a rubber band between 2 fingers...
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 04, 2008
  • Priya darshan Feb 04, 2008
    unhook it for a day or so it will work fine. I think it has
    somehing to do with a cap inside started to discharge or something and
    it lowered voltage to a chip inside then when power came back it was at
    a low voltage that caused a weird problem. When it sits with no power
    for a longer period it would go completely dead then when it was hooked
    up it was fin like it was new.
    Maybe you didn't have the unit
    unhooked from power long enough for the power to completely drain from
    the unit? let it sit over night or a few days and see what it does.
    If ur problem is not solved yet then you have to go for a replace or call a technician and fix the problem..
    Scholar:
  • 119 Answers
Well if you bought this new,i suggest you to go to the vendor for a replacement.The small engine moving the table might be brocken.Ussualy this machines are made by different separate parts which allow them to work independently*like cd or cassete)
bye
    Master:
    Sergeant:
  • 440 Answers
The moter that turns belts not working have to replace it ok thx for using fix ya .
  • Anonymous Feb 04, 2008
    unless its direct drive
6ya staff
SOURCE:
Why does my CD player say no disc?
IS IT A RECORED ONE, OR STORE BOUGHT, SOME HOME MADE ONES WILL NOT WORK.
Jul 07, 2014 | Audio Players & Recorders
Techwood problem
Failing power supply
Oct 08, 2017 | Audio Players & Recorders
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
My phone is a Nortel Networks phone T7316e I want to change my personal greeting but when i press "pers" it asks me for a greeting number. I do not know what the number is. My extension is 21...
Recording Company Greeting 1 Press FEATURE 9 8 3
The display shows
Log: QUIT RETRY REC
2 Enter 1 0 2 0 0 0 0
3 Press OK
The display shows
Admin MBOX AA OTHR
4 Press AA
The display shows
Auto Atdt Admin GRTG TABLE LINES
5 Press GRTG
The display shows
Greeting Admin GRTG AA
6 Press GRTG
The display shows
Greeting: RETRY OK
7 Enter Greeting number "13" (for holiday recordings
8 Press OK
The display shows
Greeting RETRY PLAY REC
9 Press REC
10 At the sound of the tone record the greeting.
Greeting: "Thank you for calling (your company name)..........."
11 Press OK to end your recording.
The display shows Accept Greeting:
RETRY PLAY OK
NOTE: To listen to the greeting press PLAY, to re-record the greeting press RETRY
12 Press OK to Accept the greeting
To program to play
1 From Step 12 press *
2 Press Table
Auto Atdt Admin GRTG TABLE LINES3 At Grtg table: enter 1
4 Grtg table: Retry OK
5 Press OK
6 Press OK again @ AA menu prompt
7 At Morning: 1 press CHNG to whichever new greeting you recorded
CHNG Morning: 1 PLAY NEXT
8 Continue by pushing next through all times
9 Afternoon:2 CHNG PLAY NEXT
10 You should note which times had which greetings to change back after holiday
11 After you change all the times Morning Afternoon Evening Non-business press Release
This will work for setting a new greeting as well, you can use numbers 1,2,3 etc for the greeting numbers to set them at different times of day in the table.
Feb 24, 2011 | NorStar T7316E Corded Phone
Freezes during playback
Hi. What I am trying to establish from my last question is whether the laser has become heat sensitive or whether there is a bit of dust buildup on the spindle table that might be causing the disc to have excessive wobble.
If the disc has excessive wobble, then the machine will have trouble tracking the outer tracks and will constantly skip as you have described after say 30 to 45 minutes.
If the laser has become heat sensitive then the same problem could potentially occur - The only difference being that if you were to restart the movie at that point, then the skipping would continue even at the beginning of the movie.
The first problem (wobble) is easy to fix - Clean the spindle table, the second problem may render the unit uneconomical to repair.
Mar 16, 2010 | Samsung DVD-V5500 DVD Player/VCR
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Jb 940 md player. Recording a full disc, always results in playback stopping around 38 mins. previously recorded discs will play back ok, so suspect record process not completing. When played in spare...
When you get done recording, do you wait until the "TOC" light stops flashing? If you cut off power before the Table Of Contents is written, then it can't find all your music. Even if you eject, it should still flash a little red TOC or UPDATE before it spits the disc out. Check for that. okay?
Apr 11, 2009 | Sony MDS-JB940 Mini Disc Player
Hello I just recently bought a wurlitzer 2204 jukebox at an aution I cannot get it to play the records the belts are turning, the lights are on and all the blast are lit not sure what is going on, the...
First thing's first.
At power up is the turn table turning? Is the drive motor turning? If so then the jukebox thinks it is playing a record. What happens when you press the cancel button on the back of the machine?
You should check the fuses anyway. Make sure they are the RIGHT value or you will just end up frying your jukebox if you get a serious short.
Dave F.
Nov 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Cd's wont play
can you please post here the model and the part # of the cd player.. & please kindly inform me the type of cd she play in the unit, is it a Audio CD..?
Thanks..
Apr 16, 2008 | Audio Players & Recorders
Philco (R) 841.205 CD Shelf System Logo
275 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
Perry Mellott
Perry Mellott
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
