With the drive connected to your computer, Open up My Computer, located the drive you want to wipe, right click on it and select Format, you can do a quick format. This will remove all data from the drive so be sure you do not want any data that is on it. This will also remove the WD files that came on the drive as well. If you need these files just copy them to your local disk temporally format the drive and then move them back.
Testimonial: "awesome. it worked instantly. thanks from the technically challenged!"
If you Delete all the Information on the hardrive nothing will go wrong besides the fact that all your information will get lost.Format the hardrive but only if you are sure you are comfortable with losing the infromation that is on it.
