Question about Sony CMT-EX1 CD Shelf System
Laser does not read cd. says no disk therefore cd will not start spinning to pay
  • 2 more comments
  • krewkutz Feb 04, 2008
    cd goes up and down all right. I tried openig the front, manually sliding laser, but no avail.not under warranty. I doubt it is worth paying for a fix. It is about 2 years old
    I did not know there is a rubberband in the mechanism
  • ffpa Apr 02, 2008
    I have the same problem... sometimes after shaking the tower a cd will play... looks like a problem with a rubberband inside???
  • Anonymous May 26, 2008
    I try to load a CD to play, and it opens, then closes repeatedly without reading the disc.
    The player seems to be stuck in the open/close mode. In the past, if I turn the player power off for more that a few seconds, and restart it will operate, but not recently.
    Master:
    Sergeant:
  • 440 Answers
Has bad tray cd rom would be hard to get this part also is it under warenty can u return it
Posted on Feb 04, 2008
  • nick helpap
    nick helpap Feb 04, 2008
    yes litte mech inside ther hard to getto and hard to find parts for it did ruberband break that spins it
  • nick helpap
    ya that controls it spins it sumtime sthey break but be hard job please mark this as fix ya thx nick so ithelps others
Dvd player say no disc
Hi.
If this happens with every disk that means that either the drive unit is faulty or that there is a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If that does not work, then the drive is faulty. The most common fault is due to the laser beam not emitting on the proper frequency. The red laser light is not in the correct band and the drive does not detect that there is a disk inside.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens or laser problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens or the whole drive unit depending on the fault.
Regards.
Ginko
Jul 18, 2011 | LG Televison & Video
Tip
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
on Apr 21, 2009 | Philips Magnavox DVD/VCR Dual Player
I AM HAVING ERROR EACH TIME I TRY TO PLAY A CD.
When your CD does not read any disk, and returns error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, or a faulty spindle motor unit.
If it is a lens problem, then you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , the unit will start losing the rest of functions, and ends up not reading anything at all, and returning error.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player , and clean lens directly with q tips and isopropyl alcohol, or to replace the lens, or the whole drive unit.
Sep 04, 2009 | Technics SL-MC50 CD Player
Not reading DVD and CD's :-(
May 01, 2009 | Philips HTS3450 System
My dvd-rom model gdr-8163b won't play or read . it spin once and stop
Apr 26, 2009 | Computers & Internet
My cd rom not reading any cds
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Apr 13, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
CD ROM not working
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Mar 05, 2009 | Candy CDC266 Dryer
Cd not reading
Try first using a CD/DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Feb 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Reads cd's but not dvd's
Feb 21, 2009 | Philips Magnavox MPD845
Dell D600 not reading any type of disk
Jan 14, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Sony CMT-EX1 CD Shelf System Logo
169 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
