Question about Funai PY90VG DVD Player/VCR
Py90vg recording error
I have tryed recording on memorex 16x and 8x also other brands. I get a error "cannot record on this disc" after a few seconds. Any ideas?
  • 1 more comment
  • celticgreen Feb 12, 2008
    Tried all sorts of different discs 8x 16x + -, just comes up Recording Error Can not record to this disc E4 54037380, This is even recording from T.V.
  • Anonymous Feb 16, 2008
    I looked at the manual and it says I should be able to record DVD+RW 4x but it does not work. I am using Memorex DVD+RW's
  • Anonymous Mar 02, 2008
    yes ive had 4 of these, taken back and swapped. now im sick of buying different disks and waisting my time and money and im finnaly having my money back and buying another DVD player. if i were you ide do the same.
    Dawn
    Scholar:
  • 84 Answers
Look for what format the dvd records on [ dvd-r, dvd-rw, dvd+r, dvd+rw. the manual showed tell you
wg
Posted on Feb 04, 2008
What brand of DVD do I use to record
Any brand name DVD disc like TDK,Memorex or RCA extra..as long it is 8X or 16X DVD+R format for one time recording only.Or DVD+RW u will able to Re record over the old data's was in the DVD disc earlier only.
Aug 31, 2011 | RCA DRC8335
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cannot record on 16X DVD-R
You will need to call Funai 1 800 605 8457 give them your brand / model number and expose your problem - they should be able to send you an upgrade disc but it will cost you -
If you want my advice - you DO NOT need a 16x disc inside a DVD recorder - the optical drives used on DVD recorders and even worse a Funai drive are quite bad as it is in terms of writing strats for higher speeds - you are better off recording at 8x on a 16x disc.this will provide better burns ( lower PIE/PIF errors and jitter %).
Aug 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
Can't record
hi all, spanky new, ok here my problem!! i got the panasonicdmr-e55 for xmas, 3 or 4 years ago. since then and even wheni started to use it the disc i recorded on were -R phillips 4x. since then i have tried every available manufacture of 4x's u could think of and yet to this day it will only record on a phillips 4x disc. its been in the shop a few times for cleaning and upgrades and yet they haven't beable to tell why it only accepts PHILLIPS BRAND 4X. the new upgrade i recieved fromthe manufacture was supposed allow higher in x's on disc. it accepted 16x phillips only ONE TIME AND REJECTED 50 OF THEM, SINCE THEN ABSOLUTELY NO MORE 16X OF ANY KIND. ANYONE GOT A SOLUTION????? ps even tried 8x its still a no go. i can't afford anything since i'm on social security. message: UNREADABLE DISC. SUGGEST REPLACED DISC. OK SO THIS MORNING I TRIED TDK, MEMOREX, H.P. CIRCUIT CITY, AND 6 OTHER BRANDS ALL 4X NEGATIVE R, STILL A NO GO HELP, THANKS GINA
Dec 23, 2007 | Panasonic DMR-E55 DVD Recorder
EWR20V5 DVD Recording Error
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X to 8X or 1X to 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure.....
Aug 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Rca drc8295n not recording to disc
The DRC8285N model is a great little machine, however, it will only record to DVD+R 8x disks maximum. If you are trying to record to a 16x, you will not be successful. See page 2 of your manual, and RCA service confirmed it. You can use 2.4x, 4x and 8x only. That eliminates the newer 16x format.
Aug 05, 2007 | RCA DRC8295N DVD Recorder/VCR
I cant record
I posted this in another person's question but it is probably relevant to you as well. This model (which I own myself) is outdated and needs a firmware upgrade. You might get lucky and get one from their tech support. However, I heard they stopped shipping them nearly a year ago. As it stands your recorder can only use DVD-R that records at 4x (or lower) and DVD-RW that records at 1x. Any other media is useless. Since 4x media is outdated, it may be hard to find at a major retailer. Let me know if you have any luck fixing this or finding working DVDs as I have had the same issue myself. I simply cannot find 4x DVDs in the store.
Jun 01, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Funai PY90VG DVD Player/VCR Logo
328 people viewed this question
Top Funai Televison & Video Experts
Demonic-2011
Demonic-2011
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
