NO SOUND ON SOME CHANNELS
I HAVE SOUND ON SOME CHANNELS AND NONE ON OTHERS. THIS IS A NEW PROBLEM ALTHOUGH I HAVE NOTICED SOUND HAS SEEMED TO BE LOWER ON SOME CHANNELS. I HAVE TRIED NEW BATTERIES IN REMOTE AND A DIFFERENT REMOTE WITH NO LUCK.
  • fishyrama Mar 08, 2008
    Just hooked up new antenna and now getting local terrestrial digital
    broadcasts (ATSC), but the audio is very quiet and "buried" in
    background hiss. The picture is perfect, the sound is very poor. It
    seems unlikely this could happen if reception is weak. The "signal
    strength" via the antenna setup-digital menu is 94. I also have the
    impression sound gets worse the longer TV is on.. not sure yet. Any one
    else having this problem?
  • Anonymous Jan 06, 2009
    sound on some channels and none on othes
  • 4 Answers
Suezie,
I will look into the model and see if there are any diagrams I can pull up on-line.
Are you iin the United States or another country?
The unplug and replug was worth a try.
Thank you,
Bernarr
Posted on Feb 04, 2008
The volume lowers itself all the way down to 0 and the zero continues to flash like it is still attempting to lower
You can't reset it you have a sound problem circuit that needs to be fixed by a qualified tach.
Nov 01, 2012 | ViewSonic N2750w 27 in. HD-Ready LCD...
None of the channels work. Most of the LED lights work. Im going thru the beringer mixer for power but using another mixer.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
Feb 01, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Picture set up seems really weird n i get a lot of ghosting?
sound like you have an input issue. if tv looks great on some channels and dodgy on others, could be cable or sat box issue. checking with your tv provider and schedule a service call. have them check connections and download speed from box to the pole. would also check a different input like a dvd or game console to verify problem. i would also google search your area for people with similar problems with same TV service as you. hope this helps, J
Apr 07, 2009 | Televison & Video
No sound on 2 Digital channels 20.1, or 20.2
I left the set completely turned off (unplugged) all day. When I turned the set on in the evening,
both channels had sound. So other than resetting the circuits the problem seems to have been eliminated for now. If it recurs, I'll contact you folks. This is sort of flaky, just last month I had a similar problem with Channel 26 digital in Chicago but that seems to have been resolved. Since I have 2 other Sony TVs in my house and they are NOT experiencing the same problems.
I'm not so sure my next set will be a Sony. Although I do not tune into WYCC digital in Chicago
all that much, I like to know that my set is working properly and that I'm able to look at any channel
20.1 & 20.2 included, without loosing the audio.
Apr 01, 2009 | Sony Televison & Video
Reset older analog tv
Without the original remote, sorry none. You could try pressing on any of the buttons or a combination while plugging in the unit but that is no guarantee it will reset (fully). With your indulgence, I took the liberty of checking your other posts here and here. It would seem that your original concern is that although the TV would appear to be switching to the lower channels (Ch 2-6), the TV programs on those channels would not be displayed. If yes, then I am inclined to think that there is a hardware fault internal to the TV. This would be the tuner block. The reset, even if successful, would not correct this error.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | Televison & Video
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
Red distortion
it sounds like your IR board is going out, its easy to replace and is inexpensive usually about 10.00 plus tax and shipping, and very easy to install, its one of the few parts you can buy for these models outside of the 479.00 dollar control box.
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
