Question about HP Photosmart E317 Digital Camera
Two simultaneous problems
I need to move my images from my camera to my disk. I've done this before on the menu but I've got another problem, my screen is cracked and completely white. So, I need for someone to help me out and describe in great detail what buttons to press to make that happen.
  • 77 Answers
Why not just plug the camera directly into your computer using the USB cable and copy the pictures off that way? If you are trying to copy pictures from the camera's built-in memory, just make sure you remove the add-on memory card first.
Posted on Feb 04, 2008
Canon PowerShot A450 as web cam
Please follow the steps below...
  1. Set the camera to Disk Drive mode (this step only needs to be done once):
    1. Turn on the camera, then press the Menu/OK button to display the Capture Menu.
    2. Use the Right arrow c00188560.gif button to navigate to the Setup Menuc00188561.gif .
    3. Use the Down arrow c00188562.gif button to highlight the USB menu option, and then press Menu/OK .
    4. Use the Down arrow c00188562.gif button to select Disk Drive , and then press Menu/OK .
    5. Use the Down arrow c00188562.gif button to highlight EXIT , and then press Menu/OK .
  2. After setting the camera to Disk Drive mode, connect the camera to the computer using the USB cable.
  3. The camera will appear as a removable disk in the Windows Explorer screen. You can now transfer the images or video clips to a location on the computer using Windows Explorer.
  4. When finished transferring images from the camera to the computer, disconnect the camera from the computer. If the computer is running Windows 2000 or XP, there may be an Unsafe Removal warning upon disconnecting the camera. This warning may be disregarded.
Feb 21, 2010 | Canon PowerShot A450 Digital Camera
Camera does not show in import section of 2.5 photosmart
Try Menu -> Setup Menu -> USB Configuration.
I treat my camera as a Disk Drive so the files show up in
File Explorer and open in IrfanView or can be moved to my
hard drive.
If neither the Camera or Disk Drive option for USB config
work, get a card reader and transfer the images that way.
Using a card reader is the preferred method for digital SLRs
where larger files from larger capacity cards are being dealt
with.
Mar 20, 2008 | HP Photosmart M425 Digital Camera
Pixel
the camera have a service menu that fixed it
first you must be in 24p mode for this operation
press and holding simultaneous the focus assist button(the one on the camera body)and the menu/status button for at least 5 seconds.
you see and advanced menu where the second line says CAMERA 1.
move the cursor down and push the shutter wheel to enter that menu and now you have a list with the six item being PIXEL COMPEN.
move down and select that item, the word CANCEL blinks.
change it to EXECUTE and push again. it takes about 10 seconds or so to perfom the operation and then tells you to power off the camera.
YOU ARE DONE!!
Feb 20, 2008 | JVC GY-HD110U Camcorder
I can't find the digital camera image files I saved on my PC.
Use the procedure below to search for digital camera image files saved on a PC. 1. In the "Start" menu on the desktop, open "Find" -> "Files or Folders". 2. In the "Names & Locations" window, enter the image file name in the "Named" field. Enter "DSCF" as the file name if you have not renamed the file. If you changed the file name, enter the new file name. 3. In "Look in" select the hard disk and then click the [Find Now] button to begin the search. The files found are listed in the search result. Check the results for the desired files. 4. If the desired files are not in the search results, the image files were not saved. --Saving Image Files-- - Downloading images from FinePixViewer or Exif Viewer: 1. Connect the digital camera to the PC. The "Viewer" window opens and the images are displayed as thumbnails. 2. Click "Select All" in the "Edit" menu. 3. All the images are selected (indicated by a pink frame). With the left-hand mouse button held down, move (drag) the images to the folder in which you want to save them and then release the button (drop). - Saving images from a removable disk: Connect the digital camera to the PC. When the Viewer automatically starts up, click the Close ([X]) button to close the Viewer window. Then open the "My Computer" -> "Removable disk" -> "DCIM" -> "100_FUJI" folder and select "Select All" in the "Edit" menu. Then select "Copy" in the "Edit" menu; open the folder in which you want to save the images, and select "Paste" in the "Edit" menu. All the selected images are copied and saved in the folder. You can also copy the images by selecting the entire "100_FUJI" folder.
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 1300 Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
HP Photosmart E317 Digital Camera Logo
26 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
