No channels set on tv
Olevia tv
  • bassprat Aug 28, 2008
    Selected these things on the menu, however I have Sat. TV can not scan ch's. Set is on Input-1 and Sat. Sat. is working fine, tested. No ch. indication or vol. on set. (TV)
  • Anonymous Dec 03, 2008
    no channels set on
    Genius:
  • 1,554 Answers
You have to go into the tv menu , set it for cable and then scan for channels then it will remember them.
Posted on Feb 04, 2008
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
On olevia tv, channel scan will not pick up channels 3 to 13
i think the low band on your tuner has failed
Nov 16, 2014 | Olevia 332V LCD TV
Olevia tv won't auto program you can punch in numbers but you cannot channel up it goes into mute
problem with keyboard on set front or side===likely defective switches under the plastic buttons.
May 13, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
How do I get rid of "No Channels in list" mode
it happens when we have already used and set all the channel according to our choice and some whwere it happens when you dont have more channel to view in the television ,and may me some channels are locked ,you should go through your television manuals there is evry thing you want
Oct 30, 2010 | Olevia LT37HVS 37 in. LCD HDTV
I have a Olevia 532-H that I am unable to scan under the channel set up.
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Apr 22, 2010 | Syntax Olevia 532H 32 in. LCD HDTV
I can not get my Olevia 32' tv to show cable. Does
what input do i put my tv on to get a picture it says no signal
Aug 09, 2009 | Olevia Televison & Video
No tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Jun 19, 2009 | Syntax Olevia 226T 26 in. LCD Television
No channels
Are you using a set-top converter box?
Jun 30, 2008 | Olevia LT32HVE 32 in. LCD Television
Broken tv
I had problems with channels on my Olevia LCD TV. My problem was solved by updating to the latest firmware.
http://www.olevia.com/en-us/Support/Firmware.aspx
Make sure the USB flash drive is formatted with the right file system, or the set will not see the updated firmware.
Mar 30, 2008 | Olevia LT26HVX 26 in. LCD Television
Televison & Video Logo
665 people viewed this question
Top Televison & Video Experts
Electro Med Services...
