Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Poor picture quality, pixilation, and diminished number of colors
I have a Mitsubishi WD-73727 about 18 months old.  For the last two months, the picture quality degrades after about 30 minutes.  It is as if the number of colors are changes from millions to just a few hundred - almost as if the picture was compressed to a lower quality.  This problem is present on all devices I use - whether run through an A/V receiver or direct.  I have not changes the bulb since I purchased the unit.
  • meteu399 Feb 08, 2008
    Really did not help.  Replaced the bulb.  Picture still pixilated.  Faces turn blue, colors are off.  All this occurs after tv has been on 45 minutes.
I had the exactly the same issue, even thou the bulb replacement was found to be unnecessary, the problem was solved when i took the bottom rear panel out, Either the fans are not working properly or the ventilations filters are an issue. Since i havent got any problems, i left the panel out. So far its been 4 months without any head aches.
Posted on Dec 30, 2008
I have the same t.v. it's called solarization, caused by failed color engine, (the engine in on nationwide back order cause this part of tv. is faulty from factory) cost 1800 bucks but here is the good news, contact mitisubishi the are trying to get a class action suit filed against them and they will give you a list of repair people in your area to get it fixed and they will pay for the part and the labor (but again you will be out of tv for a month most likely) if they take longer than that keep calling and buging them they keep a record of all your calls and they now waranty those tv. (weither you bout extended waranty or not for 3 years)
Posted on Feb 11, 2008
    Master:
    Sergeant:
  • 440 Answers
Get that bulb changed thx again nick
Posted on Feb 04, 2008
I have a mitsubishi WD- 6oc9 tv when i power my TV i get a steady blinking light and no picture. my husband replaced the lamp about six months ago. dont think thats the issue. need ideas on how to repair.
Sounds like lamp needs replaced. If you purchased a cheap lamp from ebay or your installer did, that is about all they will last. On your next lamp buy an osram or Philips lamp. They are a lot better quality.
Feb 05, 2014 | Mitsubishi Televison & Video
How do you do a convergence on the wd73286?
Mitsubishi WD-73286 is DLP tv that does not have any convergence circuit inside.
Convergence is required in old model rear projection tv that has three basic colors picture tubes to generate color picture that projected on front screen of tv.
DLP tv has light engine to generate picture, it is similar to multimedia projector that throws its picture on wall.
Hope this info will help.
Thanks.
Mar 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The TV keeps saying no signal with no picture but it does have sound. and it is less than a month old.
If you check the HDMI connector there may be a poor contact otherwise it looks like an under warranty repair is called for from the dealer it was purchased from.
Hope it's the lead.
Jan 02, 2011 | Mitsubishi WD-65638 65" DLP HDTV
We have color pixils (dots)(not white) on 3/4 of our screen no matter what channel it is on. Is there a way to reset the TV?
You need to replace the Light Engine,Call UED 1-800-648-6657
or Encompass Parts 1-800-638-3328
Sep 16, 2010 | Mitsubishi WD-65731 65" HDTV
I have no red color on my Mitsubishi WD-60C9 What do I do it is only 60 day old
find the menu, find, picture,color, tint, and adjust it in your desire picture
Jun 20, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mar 27, 2009 | Mitsubishi WD-73736 Television
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
