Question about HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA)
HP Digital/Analog TV Tuner color problems
It's the weirdest thing. I get people with blue faces on the screen! The picture is fine but the color is all wrong. Does anyone know how to adjust it? BTW, I have an HP Pavilion dv9640us running Vista Home Premium. Thank for any help!
    Problem Solver:
  • 4 Answers
Go to http://www.hauppauge.com/site/support/support_mce.html to down load media center drivers to run the hp expresscard tv turner in windows media center works with xp and vista
Posted on Apr 28, 2008
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Tip
HP Express Card Digital / Analog not working
First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
I couldn't get anything from HP site so investigating I found the following.
1) Had to upgrade quickplay to latest version (is pretty cool btw)
2) The card internally is a Hauppage and found that is actually the HVR1500 http://www.hauppauge.com/site/products/data_hvr1500.html.
Drivers + application can be downloaded at http://www.hauppauge.com/site/support/support_hvr1250.html
3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
Cheers
Alejandro
on Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
No problem, I just want to know if this tv has a digital tuner? It says it has a "digital comb filter". Is that the same thing?
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
I hope this helps.
Apr 15, 2011 | Televison & Video
Apex LD3249 LCD tv.picture jumps
The tv Tuner board,that where the coalax broscast signal come in is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Jul 06, 2010 | Apex Digital LD3249 LCD TV
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Part Type MAIN UNIT
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
No sound no picture.but when playing the x-box picture on and sound
I think your TV is in the A-V mode. The X Box is going into the TV through the A-V jacks. (AUDIO/VIDEO). You should be able to switch the set to tuner mode with the remote. Look for a button labeled input or go into the menu and look for "input". Stargazer
Sep 07, 2007 | Televison & Video
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
HP Expresscard TV Tuner For Windows Vista (RM436AA#ABA) Logo
247 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
vbalag
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
