Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Where do I light my gas oven?
My gas oven will not heat up and I cannot figure out where to try and light it. It is a spectra brand oven. Help! i am a single mother of 6!
  • slacker3158 Feb 04, 2008
    thanks--It does turn on to broil but not bake. I will have to call in someone to help me. thanks so much for the immediate answer!
    Novelist:
  • 130 Answers
Hello Slacker3158 how old is this oven? I only ask as GE hasn't built a standing Pilot range in over 18 yrs. The issue may be a bad oven ignitor. Put the oven on broil, if it works then the bake ignitor is bad. It is found under the bottom of the oven. There is 2 to 4 screws inside the oven that allows the bottom to be removed.
Posted on Feb 04, 2008
What causes a loud bang from oven?
If you hear a loud bang the SECOND time you try to light an oven, it means you've just had a small explosion when the gas from the FIRST try ignited outside the heating tube. I would have a professional check your oven before using it again.
Jul 18, 2014 | GE Spectra JGBP35 Gas Kitchen Range
Turn on gas oven; it lights, big poof/pop comes; then continues to light and heat properly. How do I stop it from popping? The pop is scary!! GE Spectra Gas Stove/Oven
The reason it "POOFS" is because the igniter is slightly weak and some gas enters before it gets lit,this will continue and get worse. To resolve it the igniter would need to be replaced and then as soon as the gas enters it would light it right away without collecting before it lit.
GENE
Oct 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Unable to locate where o re-light the bake burner on this spectra xl44 oven
Your oven does not use a pilot light it has a electric igniter that comes on when the oven is turned on and that is the most common thing thats wrong with a gas oven when it doesn't heat ..that the electric igniter is defective
GENE
Sep 16, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler went out on spectra how do i light it
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 21, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE SPECTRA JGBP35 Gas oven
Solved a similar issue. Sounds like your glowbar igniter is shot and needs to be replaced. While the glowbar is glowing, it is not heating up sufficiently to release gas into the oven. The heat you feel in the oven is actually from the glowbar and not from ignited gas. Replace the glowbard. Here is what I recommended to someone else:
"Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps."
Jun 24, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Spectra oven not lighting
you need a new oven ignitor for bake if its a gas stove..
May 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44
It was the igniter. The gas would go higher and then lower. The oven would take an hour to heat up. The new igniter did the trick. Thanks for your help and that link to the new part.
Mar 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
122 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
