Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
New Kodak 5300 All In one Problem
I am having trouble printing envelopes on this printer.
The sender's address is cut off, unless I set a margin of 1.9.
What should I do?
  • lolarustic Feb 04, 2008
    I don't have an A3 chioce,just A4 or A5
  • 30 Answers
Still not working.
any other ideas?
Posted on Feb 04, 2008
    Master:
    Sergeant:
  • 440 Answers
Tell it a3 envlope ok a5 in settings to print envlope an dyou size ok thx nick
Posted on Feb 03, 2008
  • nick helpap
    nick helpap Feb 04, 2008
    in the setings it self printer u know set ito envlope only ok try that 1st
Envelope address is printing at the very top of the envelope, in the center. I've tried adjusting the spacing (# inches from top) in Word under envelopes, but the printing stays in the same spot!
experiment with this
open a new document and type in the address where it would be on an envelope
when you have it in the center of the document go to print and see where it is on the preview
now while in that area click on page margins and move the margins to around what you have on the preview
then set as default
that should mean that what ever is going to be printed will appear in that part of the page or in this case the envelope as the printer and program is set to margins and everything inside those margins will be in the right place
basically it is trial and error but what you want to do is in that section of printing
Mar 02, 2017 | The Office Equipment & Supplies
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
I use the HPDeskjet D1560 only for printing envelopes. The left side of the return address is often cut off.
Check your PAGE SETUP options for the file you are about to print and ensure the values you have entered for the MARGINS (especially the left one) are set small enough to allow the whole return address to be printed.
Good luck.
Mar 31, 2011 | HP D1560 Deskjet Printer InkJet
Our printer (Kodak 5300 AiO) won't print pictures no matter what program we print them from. All we get is a few colored lines across the page. What should we be doing?
Follow the trouble shooting guide lines that came with your printer. I had the same problem and followed those procedures and then contacted Kodak with the info. It turns out that the printer head is bad and They WILL send You 1 FREE of charge and a free color and black cartrige along with it. The print head just snaps out and the new one snaps back in and You send it back in the prestamped envelope. the Printer parts are guaranteed for LIFE and are free if You follow the guidelines in the trouble shoot area.
Hope This Helps:
Aug 21, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 will not print. If the page to be
You might need a new printhead. call 1.800.421.6699 (kodak) for a new one.
Jun 29, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Kodak 5300 aio
Call tech support. They will send you a new print head.
Feb 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printing greetings cards and envelopes
At the moment it is printing both sides of Greetings cards, but this printer appears to be very sensitive with regards to placng card in the exact position in the paper tray.
Why it will not print envelopes without smudging I still don't know, so I shall just have to write address by hand after I place graphic on the envelope
This 5300 was a Christmas gift from my wife and if I could afford to change it I would. The performance is very dissapointing
Kindest Regards
David Gray
Mar 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Loading envelopes
To load envelopes that are under 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps open and toward the front of the printer. To load envelopes that are over 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps closed and the short-edge of the envelopes facing into the printer. You can load envelopes up to the maximum fill line in the tray at one time. NOTE: Make sure set the envelope flaps are completely unfolded. NOTICE: Never use envelopes with windows, coated linings, or self-stick adhesives. These lead to paper jams and damage to the printer6cf668b.png
Feb 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
87 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
