Question about HP Photosmart C3180 All-In-One InkJet Printer
The printer does not work
I gave the cartiges for refilling and ever since it stopped working. The guy at the shop talked something anout original ink and gave me something different instead. The very last control light on the panel is blinking.. ( a light next to the icon with a red cross). Can you help?
    Master:
    Sergeant:
  • 440 Answers
I would try new ink 1st orginal ink those refill ones will mess it up ok
Posted on Feb 03, 2008
6ya staff
SOURCE:
Colour cartige does not work poperly
If your cartridge is tricolor, surely one of the colors are finished, try placing the outlet on cartridge ink with a paper check you have the three color ink. Sometimes also be due to poor ink refill, I recommend using original cartridges, so you just make sure your cartridges are working properly ...
good luck
Apr 23, 2012 | Canon iP2700 Inkjet Photo Printer
Tip
How can u use a original cartige for longer period of time
u can use a original cartige for longer period of time by just refilling it before low ink level of the cartige by doing this you can use a cartige for maximum no of time as original cartige is used for once but you can again use that cartige
on Jun 09, 2010 | Office Equipment & Supplies
Hello, I have replaced the ink cartige with an kit refill ink, not with some original cartige. At first it worked, now it shows me that the Black cartige is empy even if if have made the refill. I do not...
all you have to do is to press and hold Resume button for more than 5 seconds, this procedure will by pass the ink level counter and your printer will work with no problem.
Jun 06, 2011 | Canon Office Equipment & Supplies
Does not print properly printing process run but after one or two line print it shows cartige jam/to make cartige alingment etc I have no operation manuals what can I do?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
You can download the manual from my website.
Click Link = http://www.4all2sell.com/pdf/HP-PSC-2210-2210v-2210xi-Manual.pdf
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
Feb 18, 2010 | HP PSC 2210 All-In-One InkJet Printer
I've refilled my black ink cartridge #36 and put it into my Lexmark 5650. My computer will not let me print - not even to "complete a page" print. It says that I need more ink. I have windows vistas. What...
Lexmark 36 and 37 cartridges cannot be refilled. When your ink levels drop below a certain point your printer deactivates the electronics on your cartridge so you cannot refill them. I own a Cartridge World ink refilling shop and I sell Lexmark originals for the 36 and 37 because of this reason. Unfortunately you purchased a machine that you have to buy expensive original ink for. You need to buy Lexmark original 36 and 37 to get your printer to work. As a refiller I never recommend someone buy a Lexmark printer if they ever want to use refills.
Jan 20, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
I have hp 4288 printer. Refilled cartridge does not work
ur cartidge nosel is jammed. get some drop of water on ur finger tip put it on nosel then put the cartidge nosel on newspaper because it is a good absorber it wiil help the ink to come out try for some times if it not work replace ur cartidge...
Nov 29, 2009 | HP DeskJet F380 All-In-One Printer
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer is saying its the wrong cartige
just check the wires in the printer
try to inerchange them
Jun 20, 2009 | G7 Productivity Systems VersaJette M300...
No longer recognizes ink cartridge
its always said never refill ink cartiges ... it may some times damage the print heads ...
and always use a genuine one
Feb 09, 2009 | Office Equipment & Supplies
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
HP Photosmart C3180 All-In-One InkJet Printer Logo
81 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
