Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
Sony KF60WE610 turns on and off
My Sony TV- KF60WE610 turns on for about 8 seconds and then turns off by itself. One minute later It turns on again for 8 sec. and off for 1min. and repeats this cycle. When it is on I can see approx. 500-1000 Blue pixels stuck in the middle of the screen. Need help to find out if the problem is in the light or the optical block?
  • TV is On Feb 12, 2008
    The light (costs about $140 including S & H) will fix the first problem if the TV turned on for few seconds and then turned off then on and off again. The blue pixels stuck in the middle of the screen is the other problem. This could be the optical block.
I called a Technician to ask about the problem and was told that could be 2 problems: 1- The light and 2- The optical block. I checked Sony website and found out that if the problem is in the optical block, they can pay for the repair, however, the technician from the Sony authorized service center must verify that the problem is in the optical block. This apply to several models until June 30, 2008. I guess because several customers complained for the same problem so that Sony has to extended their warranty. Please check Sony website to make sure that I read it right. Thanks.
Posted on Feb 04, 2008
  • Sony Master
  • 8,617 Answers
You will most likely need the service manual to pinpoint the problem correctly. If you do not have a manual you can ge one at the following link. I believe its 10.99. They will also email you after purchase to inquire if you would like the manual emailed out right away. I have used them many times and I always get my manuals emailed to me very quickly. Here is the Link.
http://servicemanuals.vstore.ca/
Posted on Feb 03, 2008
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
The TV shuts off by itself and then comes on 30 seconds later, it keeps doing it over and over. It did stay on for a few hours last night but then kept shutting on and off again.
First CK Fan that cools Lamp if it stops running then Lamp will shut off Fan is either defective or Ballast Board needs to b replaced But if you have never replaced Lamp it could be the Lamp CK Fan first Go to website Encompass Parts Distr. they have everything you need and Parts List as well as a service manual for your TV 1-800-638-3328
Nov 30, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony - Projector TV won't turn
Sony TV;s will give a service code, count the blinks, eg; 2-6, light will blink X amount of times, hesitate & blink again so many times. Count and report back but, I would recomend to unplug the TV's power cord, to reset the TV's system. Unplug for at least 3 minutes. I hope this was helpful.
Jun 11, 2008 | Televison & Video
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
Apr 24, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
185 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
