Question about Ellington ELN52AB5 Premier Antique Brass Ceiling Fan
Fan switch replacement, Ellington fan
I need to know what color of wire goes into my fan switch replacement. I have black, purple, yellow and a kind of orange color.
Thanks
  • bugbraxmax Feb 10, 2008
    Thanks for replying back. I finally called the manufacturer 800 number and got the sequence.
    Scholar:
  • 44 Answers
That would depend on the make and model of the fan. best to check the manufactorer web site for this information or call them if you do not have internet.
Posted on Feb 09, 2008
  • Vern Eckel
    Vern Eckel Feb 09, 2008
    by the way, guess I went brain dead there. You obviously have internet or you wouldn't have posted on the net. (duh...) check their web site and forgive my lack of thought process!!
  • Vern Eckel
    Vern Eckel Feb 10, 2008
    I am glad to hear you got the information you needed. Best of luck to you!!
When installing a new three way switch (pull string) in a ceiling fan what color wire goes to what numeber and the L on the switch ... The wires in the fan consist of a black wire that goes directly to the...
Each manufacturer has their own color code. Generally, black is hot & white is neutral. You should confirm this with a test light or a meter. To complicate things even more, some manufacturers have a receiver in the box for a remote. The best thing to do when replacing a switch with multiple speeds is to transfer one wire at a time to the new switch (with the power turned off at the circuit breaker panel).
Nov 25, 2014 | Dryers
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
I forgot to write down the color connections. my options are L 1 2 3 my wire colors are, blacr, purple, yellow, blue. which goes where?
One line on the fan goes to the house common and should be white. this one is separate from the new switch. The other 3 lines on the fan are the 3 speeds. "L" is for the hot line coming into the fan and should be BLACK or RED. It should also be in the same box connector as the white above.
1,2 and 3 are the 3 fan speeds and tie to the 3 leads on the fan.
Try 1=purple 2= blue 3=yellow
You may need to move them after testing but darkest to lightest is usually the 1,2,3 order. Please let me know how much this has helped. Thank you!
Roger
Apr 02, 2011 | Westinghouse Electric Westinghouse...
I am having trouble installing the wiring with my westinghouse. I don't know how to match up the wires. The Westinghouse has black, white, blue, and green wires, and my house wiring is purple, yellow and...
At the fan green is ground, blue is to turn on the fan, black turns on the light. I believe at your house wiring white is neutral and goes to the white in the fan. The purple and yellow are to switch on the fixtures, you can connect the purple to the blue, and the yellow to the black.
Oct 27, 2009 | Westinghouse Contempra Trio 42" Ceiling...
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
I have a westinghouse three speed fan. there are 4 wires a black, purple orange and yellow . the new switch has four connectors L 1,2,3 does any one know witch goes where? thanks , i bought the new switch...
ok. hope this helps, use a switch from FANTEC. it'll be called a 3 speed fan switch. CAM #5 No. 21105. this will also say Single Layer 3 or 4 wire application SPLIT continuity function.. THE SPLIT PART IS VITAL. now when wire it. the BLACK wire goes in SLOT 3. ORANGE wire goes in L. PURPLE wire goes in slot 2, ORANGE wire goes in slot 1. IF, and i repeat IF this does not work for you ensure you have a SPLIT CONTINUITY FUNCTION switch. NO MATTER WHAT the BLACK wire WILL go into slot 3. the ORANGE wire WILL go in slot L. switch the orange and purple wires only. ENSURE POWER IS OFF WHEN CONNECTING OR DISCONNECTING WIRES. YOU WILL GET THE SNOT ZAPPED OUTTA YOU IF YOU DON'T. please post if this helps.
May 02, 2009 | Westinghouse Electric Westinghouse...
Hampton bay ceiling fan
we have a hampton bay fan burning smell coming in didnot run
May 14, 2008 | Hampton Bay 24002 Ceiling Fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Jan 28, 2008 | Hampton Bay 24002 Ceiling Fan
Ellington ELN52AB5 Premier Antique Brass Ceiling Fan Logo
257 people viewed this question
Top Ellington Dryers Experts
john h
George Merkley
George Merkley
Bill Boyd
Are you an Ellington Dryer Expert? Answer questions, earn points and help others
