Hi , hope you can help: our Whirlpool upright freezer is switched on , all lights working but the temperature/thermostat keeps getting warmer . Once it reaches"danger", the alarm light flashes & the buzzer sounds(usually at minus 10 degrees) . We switch on/off etc. & press "Fast freeze" button( minus 24 degrees) & up to now it's sort of worked , but we are having to do this on a daily basis for the last week . Tomight those actions haven't worked at all & the freezer is slowly getting warmer! Help! Jenny Smedley
-   Same problem as Jenny T, have followed your instructions, completely defrosted, switched freezer back on temp keeps increasing now on +6. Help!
Carol-   carole ann
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool 19.6 cu. ft. Upright
mdl ev161..ser eww4838694... 4 months old.. it replaced a 10-12 year old upright. problem i have is...
(More)
MDL EV161..SER EWW4838694... 4 months old.. It replaced a 10-12 year old upright. Problem I have is after a month or so the food in the freezer gets coated with frost and I am sure I won't be able to keep food in this freezer longer than a few months. This is the worst freezer we have ever had. Purchased from Menards Indianapolis In. on 07-07-09 for $529.00 .....Any ideas?
I have an old split Philips Whirlpool fridge freezer (18M 50/50). The fridge doesn't seem to be cold...
(More)
I have an old split Philips Whirlpool fridge freezer (18M 50/50). The fridge doesn't seem to be cold enough and ice is forming on the back of the fridge when on 3.5.
Was putting ice cream on top shelf, near controls, and alarm (very loud) came on. Unplugged for...
(More)
Was putting ice cream on top shelf, near controls, and alarm (very loud) came on. Unplugged for over 4 minutes, plugged back in and still continued buzzing.
Reset on outlet pushed that while unplogged and still an alarm. Where's the reset?
Thanks in advance,
Derrick Brown
dwb@wellspringlimited.com>
whirlpool upright 2 door freezer EVL209NBTQ ... freezer is running and making a noise, but food is...
(More)
whirlpool upright 2 door freezer EVL209NBTQ ... freezer is running and making a noise, but food is all defrosted
We've got a 7 cu ft freezer that won't switch off. It is a Malleys 'Tucker Box', a famous old...
(More)
We've got a 7 cu ft freezer that won't switch off. It is a Malleys 'Tucker Box', a famous old Australian freezer. Originally made by whirlpool, I think, then that company taken over by eMail and then they bought out by Electrolux. Model number is 90-375-000
