Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
MyFi loses proper index to recorded music
The MyFi loses the proper index to recorded tunes at times. When this happens the text displayed does not match the tune. Skipping to next tune or back always lands mid-tune eventhough the display is at second 1.0 of play. How is this easily fixed?
10-4 & Thanks!
Posted on Jul 28, 2008
  • 3 Answers
Sometimes this will fix itself if you take the battery out. Otherwise, the best way seems to be to empty the memory, and start all over, recording on a blank slate. These are really pretty awful machines, with endless problems.
The on/off switch on mine just broke, and I say "good riddance."
Posted on May 26, 2008
Wavepad
Give it time. It will need to process the data. Test with a brief recording. If it takes more than ten times the length of the recording, try reinstalling the software.
Jul 13, 2013 | Computers & Internet
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
I can't figure out how to pull the stations in
MODE picks whether you receive XM or listen to your recorded music. Press MODE so you can read a specific XM channel. Then (if you have an antenna & power) you can run the dial up & down
May 12, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Myfi will turn off and on in the car. It is
Leave the battery out and see. Do you have the sleep timer set, or have it set for recordings? Try a complete reset and see if that clears things up (unless you have recorded content you don't want to lose).
Jan 23, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Recording xm
Press "mode" button so that the reciever is receiving music from satellite signal on the station you want to record. Then press "2Go" button - screen will ask you to press again to confirm - press again, and it will record whatever was being received. It will record over what was already in 2Go. In menu, under "myXm" there are choices to clear the entire memory of recorded music.
Dec 31, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi xm2go internal antenna
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
Jul 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
Sony k750i
The size
  • 100 x 46 x 20 mm
  • 3.9 x 1.8 x 0.8 inches
The weight
  • 99 gr
  • 3.5 oz
The features:
Camera Music Internet Entertainment Connectivity Messaging Communication Design Organiser Capacity: 900 mAh Stand By Time:
400 hours
Talk time:
9 hours
Display Size 176 x 220 pixels Type TFT Colors 262144
Jan 10, 2008 | Nokia 5300 Grey Cellular Phone
My XM Delph MyFi won't "record"
I get the same problem once in a while. Try removing the back cover and hitting the reset button via a paper clip--then try accessing the stored content. The MyFi should "release" the stored content.
Dec 13, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
73 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Marvin
Marvin
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
