Question about Konica 7075 All-In-One Laser Printer
Quality Issue Lately, the printer/copier has been leaving shaded streaks approx. 1/2" to 1.5" from the bottom of the page. The streaks are not wide up and down (only a little wider than a pencil mark), but the streaks vary in width going from side-to-side of the page, sometimes 1/4", sometimes 1/2" inch and sometimes 3 to 4" depending on how much time the copier has been running (it seems the more time, the worse the problem gets...) Unfortunately, the machine gets "serviced" and then 50 copies later (approx. 25-30 pages double sided per copy) it needs to be serviced again...This doesn't seem right. Any ideas?
  • brian c
    brian c May 11, 2010
    Just to verify, this IS a Konica 7075, correct?
  • 589 Answers
When was the last time a PM kit was installed?
I am actually factory trained on that model, and what you're describing sounds like a bad charge grid (which comes in a PM kit). Any contamination on it will cause intermittent "hazing" and streaking, which seems to come from no where.
Also, there are a few "tricks" I remember on these. If the tech is familiar with these machines, i'm sure he knows them.
One crucial thing is that he performs the HV auto adjustments.
Don't forget to clean the write unit mirror that Konica conveniently hid up inside the machine above the drum carriage..
If you need more help, please don't hesitate to ask.
Posted on Feb 09, 2008
Thank you, Frosty, for the input...
The drum was brand new. The tech had said he had just replaced the wires...
Yesterday, (because he was called for the upteenth time), I watched him take the section out that holds the wires, drum, etc.
Turns out that the developer? housing had wiper blades on the lid that weren't snug...also, there was quite a bit of toner billowed out on the top of the developer housing...the tech all off a sudden mentioned that he had noticed something wasn't quite right the last time he was out (but of course, he didn't do anything about it). So far I'm not sure if the problem is truely fixed yet. I know that he had replaced the developer housing unit a couple services before that with a spare one off another "spare parts" machine...the whole point of doing this was to try to put off replacing developer (because it only had 300,000 on it instead of one million) because the quality was lousy. (some shading on the top and bottom of the paper and to the average Joe its not a big deal, but I have to give my customers a quality product. He showed me how to clean around the wires, etc. So if it happens again (which I'm doubting it will), I'll be able to do it myself. Frosty, your input helped me ask some specific, slightly more knowledgeable questions. Thanks.
Nitrotrike, yes, I was talking about a Konica 7075
    Novelist:
  • 171 Answers
Hmm... there are three things that can cause this:
1) low, or old toner. obviously you'll get print issues if you have low toner, and old toner can get "clumpy" and not go on the page smoothly. Often shaking the toner cartridge can clear that up... just don't get toner all over yourself!!
3) dirty printer or wire. There is a thin taught wire that is inside the printer. Often they have a little felt brush attached which you can slide back and forth to wipe the wire and clean it. Occasionally laser printers need cleaning. Your printer's manual would have information about how to "clean" the printer.
3) bad printer drum. The drum is what statically charges the toner and paper so that they stick. If the drum has generated a small spot where it is always charged, it will always transfer toner, and always leave a "shadow" on the page. Seems to me that this would be the first thing they would check and fix if the printer gets "serviced" though.
My suggestion, is ask the people who serviced your printer exactly what it was that they did. If they just just open it up, blow out the dust, clean the printer, shake the toner, and put it back together, that won't help much if the drum is causing the problem ;)
Posted on Feb 04, 2008
2130cn printer vertical light streak about 1/2 inch wide down the paper from top to the bottom of the page. using non-dell toner BD
Hello.
The most common reason is the toner. Replace the toner with another. Use a Dell toner, if possible.
Hope this helps.
Oct 19, 2010 | Dell 2130cn Laser Printer
1/3 OF RIGHT SIDE OF PAGE DARK OR LINED TOP TO BOTTOM
Drum Cleaning Blade failure. Open up the top half of the machine as if you were removing a paper jam. Now look under the top half and about in the center from left to right. You should see a burgundy colored cylinder running from the front of the machine to the back. If you can see the toner streaks on the surface....expecially on the 1/3rd like on the copy then this will be proof that the drum cleaning blade is the cause. Simple repair for a tech that knows copier basics. A good estimated cost would be about $25.00 for the blade and whatever the going rate is for a service call in your area.
Jan 28, 2010 | Minolta EP1083 CS/PRO Copier
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Prints streaks of lines with fussy & unclear colur
Yes cleaning the LED heads do make a difference. If they are even the slightest bit dirty your output will be affected. However the quality of the prints on these printers are not very good. I have 3 of them and all of the product subpar quality (right out of the box) especially with lighter solid background colors.
On card stock (especially coated card stock) you'll notice shading on the entire page. Again this happened out of the box on all three of my printers. I researched this and read that it was an effect of the LED technology.
Also if you look closely at your prints you'll notice that there are bars in your print. These bars look like there could be something wrong with the LED matrix...
I just installed a magicolor 7450 II and man what a difference. No shading, perfect picture quality, and larger banner printing (12" x 47") Of course the price tag is a lot more ($3k)
Apr 19, 2009 | OKI C3400n Laser Printer
1" wide shaded line is appearing in center of scans
May be the scanner issue go to the authorised service centre do will do the needful
Jan 22, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Our Cannon MP 500 is leaving a 1/4" wide black streak on the back side of copies. I have cleaned off the cartridge heads, replaced the ink tanks cleaned the heads to no avail. What is the problem and how...
HI Foster,
The problem is not with the print head. Print a blank page and if you are still getting the streak. Something is probably trapped in the printer or the rollers are dirty.
Rgds
S88
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Hp Laserjet printer
a vertical stripe that is consistent top to bottom could be a laser issue, it has prisms and lenses that could be dirty or even a bit of paper stuck covering the laser light window. Dig into it and look for any debris and clean the lenses.
Hogdoctor
May 22, 2008 | HP LaserJet 4 plus Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
135 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Andrew Taylor
Andrew Taylor
richie46
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
