Question about Dyna-Glo (PPH16-LP) Utility Heater
E 1 error on Dyna-Glo Workhorse Kerosene Turbo Heater
The heater starts and runs for a short period of time, 15 -20 seconds but never gets hot.  It then shuts down.
  • 2 more comments
  • Anonymous Dec 08, 2008
    When turn on, the heater start to initiate for several seconds and stops. The message that come up is E1. I put new fuel in.
  • briana897 Dec 18, 2008
    I have this same problem. Where is the pilot orifice?
  • Vern Janisch Oct 16, 2013
    There is no pilot.. It has an electric start. There is a fuel filter that goes into the tank which may have dirt in it. I just replaced mine, about $12. Also clean the electric start mechanism. You have to take off the handle and both sides (there is one screw towards the back) then you can see the screws which holds the top shrouds on. from there it's easy to see how it works.
  • john crider
    john crider Apr 30, 2014
    where is the photo cell location to wipe it off
Take the top off of the heater and and clean the nozzel orifice, while you have it apart wipe off the photo cell and clean and regap spark plug. The nozzel unscews and you can clean it with a bread tie.
After this clean or change the fuel filter in the tank, and finally check the pump pressure and make sure it is inline with the owner manual. This is assuming that it is firing to begin with
Posted on Feb 09, 2009
  • Buds advice Feb 02, 2011
    sounds like it may very well be a photo cad cell problem. If the cad cell is dirty or broken, it does not "see" a flame and then shuts the unit down on safety. Try cleaning the front glass eye of the cad cell with a Q-tip.
Our dyna glo pro kerosene heater 2 year old heater still works, but not near as hot as it should be and has some fumes like it is not burning the kerosene efficiiently. We tried calling the manufactor from the users manual, but we hear they have gone out of bussiness. How can we get parts? We think it is the fuel pressure regulator. CFM is the manufactor.
Posted on Jan 05, 2010
    New Friend:
Remove the 8 screws, take the cover off check all the rubber hoses for cracks. take the hoses off,1 at a time and look at the entire hose for cracks. replace any cracked hoses or hoses that are loose on the nipple. i have this problem almost every year, every time it is a cracked hose.
Posted on Apr 02, 2013
  • uncle bill Apr 02, 2013
    remove the 8 screws, take the cover off check all the rubber hoses for cracks. take the hoses off,1 at a time and look at the entire hose for cracks. replace any cracked hoses or hoses that are loose on the nipple. i have this problem almost every year, every time it is a cracked hose.
You might have dust in the pilot orfice . If you do the pilot flame curves up and dosen't touch the thermo coupling enough .
Posted on Feb 24, 2008
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Fuel shut off switch
Replace the thermostat.
Jan 23, 2014 | Dyna-Glo Heating & Cooling
I have a Dyna-Glo heater, model #RMC-FA50A, heater will not get hot and there is a odar and eye burning smell after running a short time.
When this type of problem happens, you most likely need to take apart your heater and clean it well. If it still doesn't work after that, blow it out with an air compressor. If then it still isn't working, I suggest you sell that heater and buy a new one.
Dec 17, 2011 | Dyna-Glo Heating & Cooling
We bought two heaters right before Christmas and have returned both of them for replacements and the problem continues. The heater burns great for about three weeks then the wick starts to burn low and...
What you described, usually occurs when the heater runs out of kerosene or the wick is not turned up gradually, as it burns away from normal usage.
If what you described had only happened once, I would say, the wick may have been originally installed improperly by the manufacturer. But, for it to happen twice in such a short period of time, discounts that idea.
Back, before we went exclusively the selling gas heaters, gas fireplaces, gas logs, etc. We stocked, sold & serviced these heaters. They were very reliable and had only minimal problems with them. In those few cases that we did, the majority were caused by operator error ( they didn't read & follow the Owners Manual instructions) and were easily solved.
The only other thing that "may" be causing your problem is contaminated kerosene. In which case, buy your kerosene form a different supplier. And properly dispose of what you currently have.
Hope this helps solve your problem.
Mar 02, 2011 | Dyna-Glo Heating & Cooling
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Dyna-Glo (PPH16-LP) Utility Heater Logo
8,202 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
