Question about Lexmark X2470 All-In-One InkJet Printer
To purchase a power supply adapter for the printer
My printer is not getting power. looking to replace the power supply adapter
  • lamerson Mar 20, 2009
    my lexmark x2470 all in one will no longer power on - tried different outlets that i knew were working - tried unplugging it from printer and reattaching - still no go
  • pilot0881 Mar 31, 2009
    no power to my printer. exact same scenario as you described. how did you solve your problem?
    Master:
    Sergeant:
  • 440 Answers
Ebay sells replacement s take look on ther once ok thx nick
Posted on Feb 03, 2008
6ya staff
SOURCE:
Where can I buy a new AC adapter/ power supply for my Lexmark p3150 printer. Thank you
Hi There and Welcome to Fixya.
Here's where you can do a direct purchase of your Lexmark Printer's power supply/AC adapter :
Parts Warehouse
Thank you for using Fixya.
Jun 25, 2011 | Office Equipment & Supplies
Canon I960 No power
wow...that is unusual...nothing on the panel, nothing with the printheads moving?
that would suggest that the internal control board is blown..
let me check my service manual on that..
Mar 18, 2008 | Canon I960 InkJet Photo Printer
Dell Inspiron 1721 will not power on,light on power supply flashes rapidly.
First, try and take out the battery and start the computer with just the power adapter. If the power adapter is still blinking, replace the power adapter. If the computer turns on with just the power adapter, replace the battery.
If the battery status light rapidly flashes amber, the battery may be defective. Purchase a replacement battery from Dell.
If the power supply status light flashes, the power supply may be defective. Purchase a replacement power supply.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 15, 2011 | Dell Inspiron 1721 Notebook
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
Power is not comming into the printer
No power to the printer. 1) Either the power adapter is not connected properly.Remove the power cord from main power outlet and connect it to any other electric outlet.Also at the back of the printer there is a socket where the power got get connected.Remove power wire from there too and reconnect it. 2) If the problem is not solved then there are two possibilities:-- A) The power cord is faulty and needs replacement. B) Or the printer circuit board is got short and it has to be replaced. ------------ In both the cases A as well as B you need to get the fault checked by other spare power adapter or power supply board in printer.At local printer repair shops they have this parts in spare.They will get the fault checked and let you know that which part has to be replaced.Either the power adapter or power supply board.The cost of new power adapter is near to $10 and cost of new power supply board is near to $40. -------------- One more thing i want you to check is.In your printer power adapter there is one three pin power wire is connected.That three pin power wire wire goes from main power outlet to the printer adapter.In some cases that three pin power adapter gets faulty.If that three pin power wire is faulty then the cost of that power wire is just $2.So get that three pin power wire also checked. To see how this three pin power wire looks.See the fig below:--- helpmech_1.jpg
If this wire is faulty then its not much costly. ----------- This are all the possibilities that you will have to get checked.To get the fault confirmed.Thanks.Helpmech.
Dec 04, 2010 | HP DeskJet F380 All-In-One Printer
Canon Pixma 5200 printer power will not come on. It's 3-4 years old and has worked problem free until now. No known power surges and all other devices on same circuit are fine. It seems to have just...
Do you see any Light Blinking ?
If no, It sounds like Faulty Cord or might be Fault Power Supply Unit ( Adapter/Switch/Fuse ).Also, try removing the print head before replacing the power supply. Many times the print head fails and printer won't power up. If it powers up with the print head removed, you're good to go with a new print head.
The next suspect would be PCB. If that is at fault, keeping in mind the Age of Printer, better to Purchase a New One as it does not make any sense to pay more for repair than Investing in new one.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 23, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Power supply only putting out 6 volts vs. needed 12v. Router sees that as a "loose wire". Looking for replacement power adaptor.
Hi, I want to tell you that if you are looking for the replacement for the power adapter you can call netgear and you can purchase netgear adapter from the customer support for netgear. And also you can buy any other power supply adapter which have the same power supply voltage and you can use it without having any problem.
Oct 19, 2009 | NetGear WGR614 Wireless Router
Lexmark X2470 All-In-One InkJet Printer Logo
211 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
