Magnavox Color TV Model #27MT3305/17
The tv is about 2 years old. It developed a black stripe across the top of the screen where the picture is gone. Below that 3 inch strip, there is another 1 inch strip that has slight distortion and sometimes upside down picture. In time, the black will creed down to that distorted section and kill that part of the screen as well. Can I fix this problem myself? Help!!! It's Superbowl Sunday!!!! Thanks alot.
Nick
  • 8 more comments
  • Dews90 Feb 18, 2008
    I have the same TV with the same problem. My TV is also 2-3 years old.
  • bobbygladd Jun 06, 2008
    top four inches is black
  • KY52 Jun 25, 2008
    picture pulled in top and bottom,then tv shuts off. 10 uf and vert .out x'istors have been replaced.
  • red6023 Aug 29, 2008
    yes i have the same problem,tried to adjust using the remote with no luck
    black strip at the top ,with a 2'' clear strip just below the dark black.
  • alb5509 Sep 01, 2008
    I have the same problem with a 2" black strip across the top that cuts off heads with my Magnavox #27MT3305/17. It's only 3 years old, and I would hate to dump it and but a new one. Does anyone have any solutions on how to fix or how much it would cost?
  • cinderel_e Sep 10, 2008
    Hello: I have this issue too. My brother replaced cap 2465...any other ideas? Thanks, Heather
  • mrebebeb Nov 16, 2008
    has black strip across the top of screen were the picture is gone
  • Anonymous Jan 01, 2009
    My son picked up a free TV (Magnavox 27MT3305/17) someone was getting rid of and left on the side of the road. He picked it up and found out it had the same problem with the black strip at the top of the screen. I did a google search and found this site. I replaced the capacitor #2465, 10 microfarad electrolytic capacitor rated at 160 volts. The problem was corrected. Thanks for the fix. For about $2 we now have a nice TV.
  • Anonymous Feb 19, 2009
    I have the exactly same problem with my Magmavox TV. I am trying to replace the capacitor, but I dont know what screwdriver to use? It has some different screw at the back cover
  • johnconner24 Feb 25, 2009
    I have 27MT3305/17 TV and the same problem, But I cant find capacitor 2465. I can find 2463 but it seems there is no 2465 on the circuit board. Can anyone help?
    Problem Solver:
  • 16 Answers
The problem I was having was that the vertical deflection was collapsing on itself from the top. I'm a tech and I am visiting web sites who experience similar problems with the Magnavox 20 MT4405 in hopes of saving them time and money."Starsong" has the right answer. Replace electrolytic capacitor #2465. It is a
10 microfarad electrolytic capacitor rated at 160 volts. Although the existing capacitor appeared good,in circuit and out, the charge-discharge time was flat as compared with a new capacitor. Plus, when the capacitor is in circuit with full voltage applied, the capacitor leaks too much. The cost of the capacitor should be under $2. It should take under a half an hour to replace. Be certain to let your set rest, unplugged, for at least a half hour before attempting to replace this capacitor. There are high voltage present around the crt even after the set is turned off. The high voltages can cause serious bodily harm. I would suggest a tech discharge the anode on the crt with a high voltage probe passing through a volt meter and running to ground. You will need a soldering iron, solder ******, solder, and I like to use a little flux for good adhesion of component to board.
Posted on Dec 06, 2008
Change cap 2465 by the vertical output transistors. It should be 10uF@160V . Mine was so black I could hardly read it.
Posted on Mar 25, 2008
    Problem Solver:
  • 3 Answers
I love my Internet intelligence. They know exactly what's going on!
Thanks Starsong and SquareNickel!!!
Posted on Jul 22, 2010
Can't find the auto program for my old magnavox rr1948c421 it was working last week now can only get 8 ch. and can not find menu
Posted on May 01, 2008
  • 4 Answers
Nick,
Your going to need help. That upside down picture sounds like a component failure internally or possibly a set-up switch on the back panel is out of place or dirty.
Check during half-time, for a dirty switch.
Bernarr Howell
Posted on Feb 04, 2008
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
We have a sony bravia 46" tv. Model number KDL-46W4150. It is 2 years old and has now developed black lines on the right side of the picture.It goes half way across the screen. It is like this when...
That sounds correct, I just have to work on SONY BRAVIA KDL-40BR4 with Horizontal lines problem on ther right side, you you tap around the frame, the lines will come and go, this is only 2 years old TV! Poor quality panel made by SONY/SAMSUNG company jointed venture.
Very sad indeed when you paid for BRAVIA series which are not cheap.
New screen will cost more than new TV.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Feb 15, 2011 | Sony BRAVIA W-Series KDL-46W4150 46 in....
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Pink bar across top of tv screen
This could be from 2 things. 1 is the optical block is going bad or 2 you got a peice of dust blown in from the cooling fan and its blocking the color filter internally. If you are capable you can take the tv apart and blow compressed air into the color block and remove the dust. Hope this helps
May 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
There is a band developing
The band is developing across both the top and bottom of the screen it is called cinemascope picture. it is a vertical failure. it is not a major problem. it is on you accrding to cost of repair. it is due to less supply or part failure in vertical section.
Sep 24, 2007 | Philips 32PT5441/37 32" TV
Televison & Video Logo
1,362 people viewed this question
Top Televison & Video Experts
