Question about Dell Dimension 4600 PC Desktop
Boot up and time/date/year issues
Currently I need to hit F1 to boot up after I power the computer on. Computer fails to maintain current time/date/year. Even turning on the PC is weird. When hitting power strip in past, I had to still push the one button of the desktop. Now it goes on as soon as power strip is turned on.
The tower was hit hard by our chair prior to having problems. Is there a battery that holds basic start up and time/date/year memory? Could this be just loose?
  • 2,351 Answers
You are correct. There is a 3 volt battery on the motherboard. It may have come loos. This little battery holds all bios setting including the date & time. With the power cord unpluged from the Pc. Remove the side panel exposing the motherboard. Use your manual to help locate the battery. With the help of a flat tip screw driver remove the battery if not already removed & check it's voltage with a volt meter. Replace the battery, it snapes in.
With the side case off double check all power cables & data cables are connected tightly. Restart the Pc & enter the bios. Reset the time & date. As for the power strip & Pc starting. Try this. As soon as you turn on the power strip, switch the power supply's toggle switch to off. Loacated on the back of the power supply. Leave the power strip on. Give the Pc a minute. Now flip the toggle switch on the power supply to on. If the Pc begains to turn on press & hold the Pc's start button till the Pc shuts off.
Now turn off the power strip. Turn it back on. Pc should still be off. This is a reset for the PSU. Post back if you have more questions.
Posted on Feb 03, 2008
  • 86 Answers
Yes, there is a battery. It looks like a watch battery. Make sure it hasn't popped out. If it hasn't, replace it with a new one.
  • 440 Answers
Yes in the bios u can changs it from any store 3v stick new ones in there ok rate this as fix ya so it helps others thx nick
How do i bypass cmos battery
You need to have the battery in order for system to boot, however, you can reset it.
How to Clear Your Computers CMOS to Reset BIOS Settings
Oct 06, 2016 | Computers & Internet
Battery that controls the date and time when booting up
There is a 3.3 Volt button battery on your motherboard, that powers the BIOS chip so it can remember the current date and time. If you replace that battery then set the time and date the computer should no longer default back to 2008.
To remove the battery press the small metal clip towards the edge of the battery, the battery will then pop out. Simply press the new battery into place. Make sure you are able to see the writing on the top of the battery for the correct polarity.
If you attempt to do this yourself be sure to unplug the computer than press and hold the power button for about 4 seconds to de-energize the motherboard.
Should you not feel comfortable doing this any repair shop should be able to do this repair while you wait as it takes generally less than 2 minutes.
Jan 15, 2014 | eMachines ET1161-05 PC Desktop
I have finish f1 key in system plz help me
Please provide more details about your problem.
If you are seeing the "F1" prompt soon after turning the computer on, it is likely preceded by details of what has occurred and wants you to confirm the change. Reboot the computer and look at the entire screen and provide the details on the screen so we can help.
Until we get your exact issue, I will cover the basic reasons why you would see
If the message states the DATE AND TIME are incorrect, you will need to replace the small round battery that is on the motherboard. These are typically a battery with 2032 written on them and you can pick them up almost anywhere watch batteries are sold. Replace the battery, boot the computer and then go into BIOS and set the correct date and time.
If something has failed on your PC (like a stick of memory, hard drive, CD ROM drive, etc.) the BIOS would see this change and would prompt you to acknowledge this change and either hit F2 to go into BIOS and fix the issue or F1 to continue booting the computer. IF this is the case, note what has failed and then go into BIOS and either disable the drive or accept the new memory value.
Oct 31, 2013 | Dell OptiPlex GX280 PC Desktop
My desk top computer has booting problem
The F1 or F2 takes you into the BIOS setting.
The problem could be a flat BIOS battery and the Date & Time needs to be set to the current date & time.
Replacing the BIOS battery with a new one will fix this problem. When you insert the new battery go into the BIOS setting and set the Date & Time.
Dec 30, 2012 | HP Presario Computers & Internet
HP Boot problem
a1540n PC Desktop fails to boot unstated OS....
a very obsolete PC, in fact HP retired, support.
no problem really but makes getting books on it harder... facts...
  1. so did you make sure all fans work? and stay on,
  2. does the DVD drive eject button work
  3. does the keyboard caps/num/scroll locks LED toggle, when pressed
  4. does BIOS work with 1 DDR2 RAM stick (1 by 1) not 2 at once
  5. do the fans all work , up to 3?
  6. Does the F1 key work, hit fast at power on button, in 1-3seconds? immediatay after power on.
  7. did the screen show Hit F1 to enter HP setup? if yes did you?
  8. any PCI expanisin cars in the PCI slots, remove them?
  9. remove DVD and HDD cables, see if BIOS works.
  10. CPU fan Heat sink fins not packed in lent, as all are, clean it with Can-o-air?
  11. test the PSU? (ask)
The goal is BIOS screens, first. first things are first.
carbon dating retired PCs (hp zero support now)
is not easy. and is key to learning what BIOS is there (a pain)
the date you bought this PC is not important , the date it was made maters only....
standing here, i cant do that, id need to do hands on inspection
old AMD Athlon 64 X2
says ,,,,DDR2 SDRAM 2x1g it says, remove one?
NVIDIA GeForce 6150 LE TurboCache supporting 256MB
integrated, VGA.... no card. if it has a card for VGA remove it to test system using integrated VGA jack on MOBO
best i can tell, 99% off all review on pc have TIME STAMP(DATE)
but one review said it had norton 2006
so we know that one is 2006 and is over 10years old.
maybe 12 years old.. the dvd drive has date code, there in clear english, dates, if it says 2005 , there it is. other HP codes
in the PC also date the PC.
i looked up your ASUS mobo and they says its
The current bios is 3.07 phoenix-award bios.
Even ASUS dont have data on A8m2n mobos. now.
huge list of keys on PHoenix bios.
my guess is F1 or F10 is the BIOS hot key
remember HP ordered Phoenix bios under contract and HP
can in fact dictate hot keys... so HP wins here.
find the answer to this is hard. (no HP books)
hint 1: the coin cell battery can be dead, replace it on the mobo
life spans 3 -5years possible most makers top life is 7.
the goal is here, if this works we test the HDD next.
its just 2 goals, BIOS, below
then getting the HDD working and last the unstated OS working.
Jul 15, 2017 | HP Pavilion a1540n PC Desktop
Cmos bios battery is dead? press F1 to continue screen appeared for about 4 months and now pc fails to boot. how much to replace cmos batt and give desktop a once over service? thanks.
The cmos battery is a simple button cell battery and can be replaced very easily
A once over will very heavily on the service you use but i'd imagine anything up to $30.
Feb 28, 2011 | Dell Dimension 9100 PC Desktop
I get this message when I boot my computer Strike F1 to retry boot . F2 for setup utility. What does this mean? and what can I do..F1 doesn't do anything and F2 everything looks correct? any assistance...
It means that something is wrong with your setup - my first guess is that your computer backup battery has gone bad, but it may be something else.
Press F1 to retry - if the computer starts, check the system date/time (usually in the right-hand corner of the toolbar - the opposite end of where the Start icon is located).
If the computer does not start, press F2 - you will be entering the BIOS (Basic Input/Output System) and you really should not change anythig unless you are familiar with what the terms mean. BUT - it will do no harm to change the date and/or time if they are incorrect.
Exit out and the computer should now boot automatically.
If it DOES boot, then the battery is weak or dead. You will have to shut down the computer, open the case and replace the quarter-sized battery - usually 3volts.
While you are in there, blow out any accumulated dust - and don't forget the power supply.
Close the case and reboot. You will still get the error, but this time, once you reset the date/time the computer will "remember" the settings and you will be good to go for a few more years.
Dec 24, 2010 | Dell OptiPlex GX200 PC Desktop
Clock in computer will not maintain time and date
Yes it very probably is the CMOS battery, time is kept counting electric pulses, when the computer is turned on there is power and memory to do this, but when it is turned off it relays on the battery to keep this an some other settings, maybe you're receiving a warning at boot time. Check this guide for replacing such batteries:
May 13, 2010 | HP Pavilion a350n PC Desktop
F1 F2 required at boot up in VPC, not simple battery issue.
Hi im Rain.
Have you tried changiong the CMOS battery? Im sorry but the big Y2K was just the panic of people not knowing what will happen. There were no computers Reported to have been affected by the Y2K scare. Try changing the CMOS Battery If that fails then we can look into other things that may be affecting the BIOS
Jan 13, 2010 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
109 people viewed this question
Alun Cox
