NTSC/PAL Hi All, Please Help! Is it possible to change the ntsc/pal setting without using the remote control? I have a Sanyo DC-TS 760 DVD Player. Cheers My Nickname is Bluebird ;)
  • 3 more comments
  • ianto1 Feb 03, 2008
    Ooops nickname is Ianto1 :)
  • ianto1 Feb 04, 2008
    I dont have those buttons on my player .. so it seems i cannot change the setting. Manufacturers are crafty in that when a remote is lost/broken, you have to buy a new one.
    Thanks for you're help!
  • ianto1 Feb 05, 2008
    I've ordered a new remote from sanyo .. Cost me £17
    also downloaded a pdf format of the manual and it seems it my problem should be sorted once i get the remote :)
    Once again Thanks for you're help!
    Got the remote control .. however, my picture is still black and white even after changing the setting :( ... any ideas?
  • ianto1 Feb 06, 2008
    Problem Sorted :D ... was a faulty scart lead :)
    Novelist:
  • 171 Answers
Surprisingly, and I've never understood why this is, the remote has a lot of functions on it that the buttons on the dvd player doesn't have. I think it is more likely that it ISN'T possible to do.
Look on the front of your DVD player. If it has a "menu" button and a four-way directional pad, you may be able to stop whatever dvd is playing, go into the dvd player's menu and change the settings that way. If not, then you can't.
Posted on Feb 04, 2008
  • Frosty555 Feb 04, 2008
    Tell me about it. It is really annoying.
    Occasionally you can get a universal remote control that will also give you access to the basic menu functions on the dvd player. So that's another direction you can try. Of course, it is hit-and-miss. One universal remote might let you while the other doesn't! ;)
    Thanks for the rating, btw.
Pioneer DVD player the screen will not stay still
maybe the dvd is st to pal/secam, and your tv is set to ntsc...look for the pal/seca/ntsc button in your remote control of dvd player and set the player to ntsc...tv recievers are set to ntsc by default if you are in asia...
Oct 15, 2014 | Car Audio & Video
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
I am trying to play dvds from England (Region 2) on this dvd player and bought it specifically because it is region free - plays NTSC and PAL, so thought it would be an obvious choice. I can get the dvd to...
Are you in the US? Your TV system is NTSC. The player possibly plays NTSC and PAL(European system) discs on PAL TVs only. Try to find out from the user manual of the DVD player if you can change the output signal to NTSC. Now it is PAL even though you are playing NTSC discs.
Oct 14, 2013 | Pioneer DV-3032KV 1080P Upscaling Region...
How to convert sanyo dvr DSR300N(NTSC) to DSR300P(PAL)?
You have to buy one NTSC to PAL signal converter for this, and connect it in beween your tV and DVR.
Apr 21, 2012 | Sanyo DVR-120
I have attached a DVD Player to my LG TV, using the appropriate cables. I have sound and a black & White picture. What have I done wrong please?
It is very simple, the mode of your DVD or TV is not correct. Check the NTSC/PAL setting's on your remote control for the DVD player. If your DVD player is on PAL system, then you TV should also be on PAL system. Likewise for the NTSC system, possible to put both on AUTO mode then do it. Don't get confused it is just a simple setting which you can do it without any problem, and in future you can do it for others.
Mar 04, 2011 | LG Televison & Video
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
Set up video output
Pal output will only work when it is plugged into a pal tv. The only way you can restore is to use the remote to put the settings back to ntsc without using the display. That should work. If you don't have a pal tv you should never change devices to run on it, because it can damage your tv set. The scanning lines are very different between the two systems.
Aug 14, 2008 | Cyberhome CH-DVD 300 DVD Player
PAL problem
Hi!
The DVD player you have is only compatible with NTSC TV. There is no way of changing that to PAL.
It is compatible though with PAL discs. It will convert the video signal of a PAL disc to NTSC format.
Dec 21, 2007 | Philips DVP3140
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Televison & Video Logo
292 people viewed this question
Top Televison & Video Experts
Electro Med Services...
