Question about Westinghouse LTV-37WI 37 in. LCD Television
Westinghouse 37', hd scan
Everytime i turn my tv off and turn it back on i have to rescan my hd channels. does anyone know why this is?
  • westlv Jun 16, 2008
    yes, direct wall to tv.
  • Anonymous May 11, 2010
    are you using a settop box or a direct wall to tv connection?
Direct wall to tv
Posted on Jun 15, 2008
6ya staff
SOURCE:
I DONT KNOW CHANNEL LOCK PASSWORD ON MY THORN TV
Hi, on my TV I do it like this.
Press the 'Input/Source' Button.
Press '2, 5, 8, 0' on the keypad of the remote.
This should either send you to the factory reset options or will pop up a screen to give the option to rescan channels.
IF you see "Reset All" then press "OK".
This will turn your TV off, completing the reset procedure.
Please turn your TV back on, and scan the channels again.
Otherwise you should just select the Rescan your channels option.
Cheers
Jul 13, 2017 | Televison & Video
Toshiba 40 inch not pickingup channels in scan
Tuner is ng. You can check out the repair cost but ......Another option is to buy an external HD tuner and feed that signal to your set via HDMI inputs. Cheaper than a repair.
Available on ebay eBayeBay
Sep 13, 2017 | Lands Phones
MY Westinghouse tv has lost channels i tried to scan them back in but it didnt work tried unplugging it and then scanning it again it still didnt work I have lost the manual please help
im having the exact same problem, suddenly i turn it on and it only shows channels in the hundreds, with no picture, and i reset it several times with no result. help!
Jul 17, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Sep 12, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
After the dreaded "Switch" I lost nearly all free HD channels. Prior to the "Switch" I got roughly 40 HD channels. Now I have 2 that work. Can anyone not named Dubya explain this?
I had a similar experience. The way I solved was to go back to the set-up and have the channels get re-scanned in. Even though I had gotten channel 22-1 originally the frequenciy must have slightly changed with the switch over because once the television rescanned it in it worked just fine.
Jun 29, 2009 | Westinghouse SK-26H590D Television
I have a westinghouse sk-32h240s whin i retune it
No. Everytime you rescan channels it will dump any previously saved channels.
Jun 23, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
SETANTA
If Setanta shows up as a channel, but is just not accessible, then it's not a scanning problem.
In this case the problem may be with the viewing card or CAM not inserted correctly. The CAM needs a good push to insert correctly. Also, it is not obvious which way round the CAM goes into the TV. Try both ways. There will be hard resistance if the CAM is the wrong way round. If there is not hard resistance, then it probably needs pushing in a bit more.
If Setanta doesn't show on the channel list, then the problem is more likely to be to do with your signal.
Apr 17, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
Feb 21, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
LTV-40w1 HDC Westinghouse TV
I had the same issue. I just bought this tv. I went to source on the side of the tv pushed the input button til it went to YPbPr1 and the screen came up. My HD cable box is a little old so I'm using that instead of HDMI. But if your using HDMI just keep hitting that button til you see HDMI and it should work.
Sep 19, 2007 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse LTV-37WI 37 in. LCD Television Logo
133 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
