Question about Palm Zire 31 Handheld
Trying to insert a 2gb expansion card into my palm
Im having trouble getting my palm to acknowledge when i insert a sd card. It keeps saying no card installed!!
    Novelist:
  • 171 Answers
A lot of palm haldhelds only support SD cards up to 1gb. The 2gb and up ones are not supported. So check your manual and figure out waht the maximum size of sd card is in your palm, or try a smaller size SD card.
Posted on Feb 04, 2008
Camera keeps saying memory full but have inserted new sdhc card
The S1030 works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
Sep 08, 2012 | Samsung S1030 Digital Camera
I put my 16g sd card in my phone but it keeps saying insert an sd
it could be that your phone does not support high capacity sd cards (SDHC). Check the users manual to see what types of cards it supports and if SDHC is listed.
Jan 20, 2010 | SanDisk 2GB microSD Memory Card
Won't read memory card
This usually indicates that you are trying to use 'newer' SDHC High Capacity cards of 4GB or more. Older and cheaper units like this Vivicam 5024 unfortunately may be limited to 2Gb 'standard' SD cards.
Hope it helps: let me know what cards you are trying to use.
Jan 16, 2010 | Vivitar ViviCam 5024 Digital Camera
Memory card cannot be identified
Palm devices will only accept a maximum of 1GB SD cards. Sorry.
Feb 22, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
Feb 14, 2009 | SanDisk 2GB microSD Memory Card
LifeDrive will not recognize SD expansion card
If the sdcard is the right type and size all you need to do is fully insert it into the slot. Its spring loaded so it will pop up if it isn't quite far enough in. It should only fit one way.
Generally the LD likes 2gb and smaller sdcards , it can use bigger such as 4gb but that's when you can be hit or miss. That depends on brand and sd version.If you search for a list of LD compatible sd cards you should find out what card to use or buy.
Jun 17, 2008 | Palm LifeDrive Mobile Manager Handheld
Palm Zire 72
Make sure your card is an "SD" card and not "SDHC" which means you can only use expansion cards up to 2GB only. There are, however 4GB SD cards, but are now either hard to find or are more expensive. There are SDHC drivers around but you have to pay for those.
May 13, 2008 | Palm Zire 72 Special Edition Handheld
Lifedrive wont read anything in expansion slot
FOrmat the Card and see if it works
Sep 17, 2007 | Palm LifeDrive Handheld
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Finding data on SD or MMC
The Palm OS "Find" application does not look at the content in SD or MMC expansion cards inserted in your handheld. It only searches through data stored in the internal memory of your handheld. There are many third-party searching utilities available.
Palm Zire 31 Handheld Logo
242 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
