Question about Frigidaire FGF378AC Gas Kitchen Range
Loud clicking sound does not stop
Range is no more than 1.5 years old. Used rarely. Turned on broiler and there was a loud clicking that did not stop. Flames of broiler worked. Burners light and function. Clicking did not stop. Unplugged the stove. Clicking stopped when unplugged. Left unplugged overnight. When plugged in again clicking resumed. Sound is similar to a starter click, but does not stop.
Any suggestions. Does not make me want to buy more Frigidaire products.
    Genius:
  • 1,554 Answers
The igniter circuit is stuck the circuit that controls this is shorted out and you cannot likely fix this. The controlling scr transistor is bad. its on the main board. It happens
Posted on Feb 03, 2008
We have a 20" Estate
LOOK FOR PROBLEM WITH THERMOSTATE
Feb 02, 2011 | Estate TEP200VAQ Range
Tip
Verrrry interesting. Chap. One. We had a serviceman at the house this morning...
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but can be found with the technical documentation that comes with your range. Most manufacturers place a tech sheet somewhere along the back of the range, or inside the console for qualified technicians to use as a troubleshooting aid. Refer to this if an “F” code is displayed on your operator console. The probe may also exhibit other symptoms without generating an error code. You could have undesired heating results (too hot or too cold), or slow preheat times.
The location of the oven probe can vary on different models as well. It will be mounted on the back or side of the oven wall (usually in the upper right or upper left corner). If you suspect you have a bad oven probe, a resistance check can be performed to determine if the probe is good. To accomplish this, unplug the range and remove the back panel. There are still dangerous voltages present even when the oven is not on. There will be two heat insulated wires coming from the oven probe behind the oven. Disconnect the wires and perform a resistance reading across both wires at room temperature. If the probe is good, it should read around 1100-1200 ohms*. If the reading is too low (shorted) or too high (open), replace it. However, I would take a good look at the interconnecting wiring FIRST. If you have a connector plug on the oven probe, often the plug pins will oxidize and not make good contact. This gives false readings and can lead to erroneous error codes. Some manufacturers recommend cutting the connector plug off completely and hardwiring the leads together by using heat resistant ceramic wire lugs. This provides a more permanent and reliable connection. The lugs can be purchased at most hardware stores. A new oven probe roughly costs about $35 - $45 and can be found on line at several appliance parts websites. Higher end model prices may be more.
To replace the oven probe, simply remove the mounting screw from inside the oven cavity, disconnect the wires and pull the probe out. Insert the new probe by feeding the wires through the opening in the back of the oven first and out the back through the insulation (a long screwdriver can assist you in making a visible hole through the heat insulation to feed the wires easier). Once you have the wires through the back of the oven, reinsert the mounting screw and connect the wires leads together. Reinstall back panel.
*NOTE: Keep in mind resistance readings will be higher if the probe is hot. Make sure you check the temperature at room temperature.
I hope this information is helpful..
on Apr 07, 2008 | Maytag MER6772 Gemini Electric Kitchen...
My recently purchased lg electric range came without a broiler pan. When I asked my Home Depot appliance salesman he told me that broiler pans are not supplied with the range.unfortunately I tossed the old...
It is rare for a Range Mfg. to supply pots/pans/or other cooking instruments with their products. Yes, you should have saved the old hardware. I suggest you seek new cookware from eBay, Amazon, or WalMart.
Jan 12, 2018 | LG LRE30453ST (Electric) Stainless Steel...
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Broiler element broke and was burning as if it was being welded
Probably none. The sparking going on after you turned it off was probably the ground side of the element. Replace the element then re apply power and see if you have any trouble then.
Apr 06, 2009 | Kitchen Ranges
Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Stove is suddenly haunted
F3 Oven too hot Replace oven temperature sensor it also sounds like you need a main control too..hope this helps
Aug 25, 2007 | Kenmore 75503 Stainless Steel Dual Fuel...
Frigidaire FGF378AC Gas Kitchen Range Logo
529 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
