Some people, when their computer reaches the point that it can't run the programs it once used to, decide to toss their machine and invest in a new one. Others squeak out some extra life by overclocking their processors. While this is ideally done with hardware, for pre-built HP computers you will have to use a software option. With this minor exception, the process is still a breeze.
Download and install CPU overclocking software, such as ClockGen, SetFSB or SysTool (see Below).
http://files.extremeoverclocking.com/file.php?f=189 http://www.softpedia.com/get/System/Benchmarks/SetFSB.shtml http://www.techpowerup.com/systool/ While all these programs more or less work the same, for this guide we will be working with ClockGen. Boot the CPU overclocking software. Do not be alarmed if your computer momentarily slows down, as the software is reading your CPU's clock speeds. Click "PLL Control" or the equivalent in your overclocking software. This will show you several sliders for your front-side bus (FSB) and, in many cases, your PCI cards. Adjust the FSB slider. Be sure to do this slowly, as the processor will likely fail if there is a sudden speed change. For best results, use the arrows to slowly adjust the settings by one-to-two megahertz at a time. Click "Apply" frequently to set the speeds. Hope this helps.
http://h10025.www1.hp.com/ewfrf/wc/docum... is this the battery you are talking about?
