Question about Gaggia Classic Espresso Machine
Seal Kit How/where can I get a seal kit? Will I be able to do the repair myself or is it too involved for a beginner?
Gaggia Gasket Seals can be purchased from most good online suppliers
These can be replaced pretty easily and if required I can provide a step by step instruction guide how to do this.
Posted on Nov 23, 2008
What is involved with repairing a leaking 357 Crosman. What is in the kit ?
What's in the kits is listed here. Usually piston seal/Co2 seal, chamber o-ring and oil. There are videos showing how to do the repairs.
357 Crosman repair kit Bing images
Jun 18, 2016 | Optics
Bostitich, N16, Nailer I am looking for seal kit, O ring kit, and # 42 Top Bumper please advise if you can help. Daryl Thomas
The parts are available from here:
http://www.mastertoolrepair.com/bostitch-nailer-p-4136.html
I have also seen parts on ebay. Look for oring kit on ebay costing about $20. Or bostitch repair kit ork-11 costing about $30. Just search on ebay for "bostitch n16" . Good luck
Jan 11, 2011 | Stanley Bostitch N16 Nailer rebuild Parts...
Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
May 28, 2010 | Speed Queen AWS44NW Top Load Washer
How much should a head gasket repair cost on a kia 2005 sedona
Probably around $1000.00. It's a rather involved job.
May 21, 2010 | 2004 Kia Sedona
Ford 770 loader front cylinder leaks fluid when operated forward or back. repair process for changing seal
61506-fd.jpg Ford Lift Cover Repair Kit (770)
$10.00
Ford Lift Cover Repair Kit. Fits 500 thur 4000 . Repalces: 3B5564
depending on year of your tractor it takes a rebuild kit, assuming your cylinder and ram are in good shape and free of rust, nicks and scratches, if the ram is damaged a new seal kit will be shortlived, its pretty straing forward repair, the only thing you may need is an adjustable spanner wrench set to remove the endcaps hope this steers you in the right direction
Nov 22, 2009 | Ford Garden
How do i get a bosch front loader drum apart, to get the bearings
THIS CAN BE DONE EASILY WHEN YOU HAVE DONE A FEW LIKE ME, HOWEVER FOR A BEGINNER ITS QUITE INVOLVED IT TAKES ME A COUPLE OF HOURS TO DO.YOU WILL NEED A NEW REAR TUB SECTION COMPLETE WITH BEARINGS A TUB SEAL AND A SEAL KIT (NEW BOLTS INCLUDED) AND POSSIBLY A NEW INNER DRUM AS REMOVING THE INNER DRUM FROM COLLAPSED BEARINGS IS NOT EASY WITHOUT DAMAGE TO DRUM SHAFT,IF YOU STILL FEEL CONFIDENT REPLY TO MY POST AND I WILL GIVE YOU MORE ADVICE.
Sep 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Repair kit for fok telescope problems
remove the fork from the bike,remove the dust cover over the oil seal,this will expose the fork seal that is leaking,remove the seal(probably have to stab throgh it with a screwdriver to get it out)measure the seal outside diameter and the diameter of the fork leg,take the seal and your measurements to any motorcycle shop and they should be able to match up a new seal...replace the seals in both fork tubes,as if one is leaking the other one will fail soon
Jul 03, 2009 | 2004 Skyteam ST 125 SM
Hole in door gasket of a Hotpoint 9901w washer dryer.
It is quite involved to change the seal, as requires a partial strip down, if the hole is not very big, then you can do a fairly good repair using a bicycle punture repair kit..
Remove the plastic clip that holds the clamp ring on the front of the washer seal at the top, remove the clamp ring, take note how it is fitted, then pull seal off front of washer, and fit patch on underside of seal, refit seal and clamp,and job done!!!!
Plz rate my solution.
Thanks.
Jan 25, 2009 | Washing Machines
Seal/Gasket kit for Powermate 4-Gallon air compressor Model #VP0000401
Just some information that may lead you to parts, The compressor sold thru Lowes (Kobalt) must be the same mfg. because the parts look like they would interchange. A trip to Lowes may verify. Maybe they have a compressor with bad motor for your parts. Good Luck
Dec 10, 2008 | Air Tools & Compressors
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Gaggia Classic Espresso Machine Logo
164 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
