Question about Jensen 143307 Remote Control
Input i have a Toshiba TV 27af46 ! there are two codes that control this tv but in any of them i can change the input!! so i can display my dvd and x-box! and particularly this model does not permit me to do it manually! I'll really appreciate a rapid answer !! i'm using a jer422 3651 jensen control!!
  • emildrin Feb 03, 2008
    i was suspecting it!! thanks to comfirm it!!
  • Steffany Oct 26, 2008
    I cannot change to game player (Wii) or VCR or DVD with Jensen Remote why do they make this remote so you cannot switch with the input button. Why put an input button on a remote when it does not work? Well, I guess you get what you pay for! And....the website in the instructions doesn't work, so NO customer support Whatsoever, AND no phone number AND someone destroyed the packaging so I can't even return the @!#% REMOTE! ok rant over now :)
    Master:
    Sergeant:
  • 440 Answers
U will need orginal tv remoteto change its inputs or logitch harmony ok
Posted on Feb 03, 2008
  • nick helpap
    nick helpap Feb 03, 2008
    mark this as fix ya then please so i get crdit and it will help others ok thx nick
I need the universal remote control code for Toshiba MD20P1 20 inch TV/DVD combo.
Enter code 20695 for both the DVD Control and TV Control. This worked for a motorola universal remote with a Charter cable box.
Jan 19, 2011 | Toshiba MD20P1 20 in. TV/DVD Combo
I have a Toshiba SD-K860SU DVD video player that I have connected to my Panasonic TC-32LX60 LCD TV, but I cannot get the DVD player to work. My TV is connected to my Comcast cable service black box. Should...
You should use the component video input (which ever the TV has), you will get better pictures than the S-video.
As far as the remote control for the DVD, keep using the one that comes with your DVD player, Comcast remote does not always work, beside you get full function using the DVD's remote, that is how I use my DVD, same for the TV, Comcast remote my not be able to send out the signals to the ATV for selecting the input sources on the TV. Comcast remote is not a full functions remote.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 06, 2010 | Televison & Video
I just got a toshiba theaterview sd dolby digital
That particular TV has both "component video" and standard video inputs. The DVD player might have a component video output (it will be three separate connectors of three different colors.) You will need a component video patch cable available at most electronics stores. If your DVD player doesn't have that input then use the standard video connector, yellow wire connects the video out on the DVD player to the Video input on the TV. The red and white wires are the left and right stereo audio connections they also make a cable for that. It will be color coded so make sure you match the codes from the output to the input on the TV. This set has two video inputs, you will get your best resolution if you use them instead of a "channel" input.
You will need the remote to select the video 1 or video 2 inputs. You can connect your DVD player and your game at the same time. Just use video 1 for the DVD and video 2 for the game. They require the yellow, red and white connector cables. Just follow the color code and match the colors with the jacks on the TV and other units. There is actually a third video input Video 3 behind the little door on the front panel. That would be convenient for the game if you want to remove it easily when not in use.
Push the menu button on the remote (big button in the middle) go to the video function and select either Video 1 for your DVD, Video 2 or 3 for your game.
The correct video input for what you want to view is important. Also if you don't have the user's manual it's available for free here: http://tacpservice.toshiba.com/ConsumerProductSupport/Manuals/TV/2003/32A33_32_36A43%28E%29_A.pdf
You might also need to download an Adobe Viewer which allows you to read .pdf files.
That is also available for free at:
http://get.adobe.com/reader/
If you already have malware protection (viruses and the like) un-check the MacAfee box so you don't download that too.
Zashiban
Jun 04, 2010 | Toshiba 32A43 32" TV
My Toshiba model number 51H83 has picture but no sound. I put a dvd in and the sound worked but when I went back to TV no sound. I dusted the back of my tv yesterday and since then have had no sound. Tv is...
Are you using the rf antenna input for TV or 1 of the VIDEO inputs from a cable box or sat receiver. If the latter check to see if you unplugged the audio fron the box White and red wires from box. If thats ok Plug that dvd player into that input using the cabes from the dvd player .If you now have sound change ables from box. if still no sound cable box bad. If still no sound from that input check for solder connection on input jacks. If antenna input is used replace the tunner intv.
Mar 25, 2010 | Toshiba 51H83 51" Rear Projection...
YOUR TV DOES NOT ALLOW DISPLAY OF THIS PROGRAM THROUGH THE DVI IN
I solved the same problem by disabling SIMPLINK from OPTIONS menu. I own the LG TV myself. The LG TV comes SIMPLINK "ON" as default setting from the factory. Go to MEMU -> OPTIONS -> Turn SIMPLINK to "OFF". This should work....
Sep 18, 2009 | Toshiba D-R5 DVD Recorder
Connected DVD Player to TV using HDMI cable doesn't work
Have you changed the input of your TV unit to AV1, AV2 or component...or what ever? If so and yet the problem prevails, then try to Plug the AV cable to the input of your Cable Box, if it has so.
If i was helpful, kindly do Rate!
Jul 21, 2009 | Toshiba XD-E500 DVD Player
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
I have a 2004 Toshiba color TV 27".
simply look up the codes or contact your cable company for the toshiba tv codes to input into the cable remote. you may also be able to operate the cable box via the TV remote if the correct codes from the tv owners manual are entered.
Nov 25, 2008 | Toshiba 27A33 27" TV
HDTV cables
Pressing INPUT on the remote control
displays the current signal source
(press INPUT again or 0–8 to change and be sure is on hdmi 1 or 2 if not let me know , to reset to the factory default settings
your raring to my answer highly apreciate
thanks
Jun 29, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Hooking up external DVD player
if you tryed to hook up into another video input you also have to switch the inputs on the remote in the input menu from input 1 or 2 to the same.
May 27, 2006 | Toshiba MW20FM1 20 in. Combo
Jensen 143307 Remote Control Logo
236 people viewed this question
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
