Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite Trio model#596.73503201
The water dispenser on our refrig. stopped working. I saw another post on this issue, but Im not sure if its the same reason. I can hear the dispenser working but nothing comes out.. I opened the filter compartment and it fills with some water. If the water is going to the filter, but can not go past... do you still think something could be frozen from that part to the dispenser? I do notice that items placed in the rear of the refrig. sometimes freeze. I just lowered the temperature hoping that is the issue, if its not working by tomorrow, Im hoping you have another idea. Thank you!!!
    Novelist:
  • 130 Answers
I believe you may be on the right track. Usually the coil for the water is behind the crispers. You can try taking the crispers out and use a hairdryer on air/no heat to speed up the coil thawing out.
Posted on Feb 04, 2008
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
May 28, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Ken more elite trio model number 596-73502201
Make sure water is turned all the way on. If still not getting water, you might have to check the screen inside the water valve to make sure it's not plugged. Also make sure your electrical connection on water valve is on securely.
Nov 10, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
I have the Kenmore Elite Trio 795.75546401. There is a sheet of ice under the freezer draw. I cleaned it out and it came back. Have since shut off the ice maker and stopped using the water dispenser. I...
It is definitely the water filter. With the hardness of the water from our county I have to change our filter every 6 months. After replacing the filter be sure that it is seated well. It can leak if it is not fully engaged. Run water through the dispenser until the air is out.
Mar 02, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
No water or ice or lights on outside of door
I received my Elite TRIO 795.7101 2 weeks ago. I have ran over 3 gallons of water though it. I am still getting a bad odor and taste when I dispenser water from the door.
Nov 03, 2010 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Dec 30, 2009 | Kenmore Refrigerators
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
640 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
