Question about Denon DRA-395 Receiver
Denon dra 395
Was playing the cd palyer and the power went out. I bought a new fuse and did what the book suggested: unplug the power cord press speakers a and b and it did not restary although the speaker buttons flashed and the power button is on. second time we have had this tot he service center adn it is only 3 years old. any ideas?
Laura Ryan
SOURCE: Denon DRA 395 volume creeps to max by itself
I also had this problem with my Denon DRA 395. I fixed it by replacing the batteries in my remote! Apparently when the remote batteries are nearly gone, but not 100%, they are capable of prompting the remote to unilaterally increase the volume at irregular intervals. It was kind of spooky!
Posted on Oct 17, 2007
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
  • 119 Answers
SOURCE: receiver cuts inself off about 15 seconds after you turn it on
you need to check your speakers connections to make sure nothing is touching and all is connected right and not to have to many spkrs on the channels, also only have the skrs on that you are using, make sure zone 2 / 3 are off and multi volm is turned down
Posted on Feb 25, 2009
  • 100 Answers
SOURCE: Did a INITIALIZATION OF THE MICROPROCESSOR . Did not help.
yes you can do it by your self
Posted on Jul 17, 2009
Denon DAR-395 sparks
You most likely have shorted output transistors. This will cause the fuse to blow, and usually burns up a couple resistors as well.
Apr 22, 2013 | Denon DRA-395 Receiver
Is the denon dra-395 compatible with an ipod?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 13, 2011 | Denon DRA-395 Receiver
We bought our Denon 395 4 years ago. Is it set up for HDTV and IPhone (IPod) use? Also, how can we get a manal as it was lost in moving. Charles Barrett cbarrett1410@yahoo.com
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-DRA-395-Receivers-manual/id/363ci767/t/2/
It is an analog STEREO-only receiver so it is NOT compatible with multichannel or even digital audio. The TV is irrelevant.
Re: the iPhone:
Dec 29, 2010 | Denon DRA-395 Receiver
AS SOON AS I TURN ON MY DENON-395 RECEIVER IT TURNS OFF
I REMOVED THE AM LOOP ANTENNA. AND THE UNIT WORKED. TO MAKE SURE THIS WAS THE PROBLEM I REMOVED AND REPLACED IT SEVERAL TIMES. EACH TIME IT WENT OFF AND. I THEN PUT ON THE FM INDOOR (WIRE) ANTENNA. THE UNIT BEGAN TO PLAY BEFORE EVEN BEFORE I CONNECTED IT. JUST GETTING IT CLOSE TO THE FM COAX. MADE IT WORK.
Oct 28, 2009 | Denon DRA-395 Receiver
MY DENON DRA-435 A RECEIVER JUST WENT DEAD..NO POWER, CHECKED AC CONNECTION OK! NO RE-SET VISABLE..SUGGESTIONS?
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Jul 23, 2008 | Denon Audio Players & Recorders
Mar 27, 2008 | Denon DRA-395 Receiver
Oct 01, 2007 | Audio Players & Recorders
Denon DRA-395 Receiver Logo
82 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
