Question about Whirlpool MH1150XMQ Microwave Oven
Burnt ceiling I was using the microwave when there was a buzzing sound and a hole was burnt through the ceiling of my microwave, can it be fixed ?
    Novelist:
  • 130 Answers
Yes it can. There should be a mica cover on the top of the microwave. Usually grease will build up there and when it gets to hot will burn thru the paint. That was the buzzing you heard. I have used white touch up paint in a bottle with brush in the cap to fix the bare sheet metal. Then you can reorder the mica cover. Around 20 dollars.
Posted on Feb 03, 2008
Well microwave probably was too close to the ceiling and it wasn't getting enough air through and it got hot then bam you have a hole in your ceiling... if your microwave is completely ruined then don't bother with it just get a new one but if it works try moving it farther away from the ceiling.. good luck =]]
6ya staff
SOURCE:
At times i see oil leak from the top part of the microwave oven.The oil leak drips from the a hole in the microwave oven ceiling. What should I do?
That is called dirt. From not using a cover on your food. any hot oils will precipitate back on the ceiling.
Oct 19, 2013 | GE Microwave Ovens
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
My microwave is making a loud buzzing sound. Inside the microwave, on the upper right side, is a square area with holes in it. It sounds like the buzzing is coming from behind those holes. Also, after...
THe buzzing noise is most likely coming from the magneton. The magnetron is the main component of the unit (it generates the microwaves). Replaceing it can be very expensive. You may be better off getting a new oven. Prices for new microwave ovens have dropped significantly.
Jun 12, 2011 | Microwave Ovens
I have Danby microwave, the food does not heat and there is smells like some thing is burnt. I have opened it and the high voltage transformer does not look burnt.
What is happening is that the magnetron is shorted, causing the high voltage transformer to overheat. That is what you are smelling is the insulation getting hot. When the magnetron shorts out, it makes a loud buzzing sound. Replacement magnetrons costs almost as much as a new oven so it rarely makes sense to fix.
Mar 09, 2011 | Danby DMW902 Microwave Oven
Ge microwave jvm160wj01 was working and suddenly started buzzing, gave bad electric/burnt smell and buzzes. Still buzzes and does not seem to heat now.
Sounds like the magnetron just shorted out. Its the part the generates the microwaves that heat the food. Buzzing sounds are a symptom of a shorted mag. Usually not worth fixing since the magnetron costs almost as much as a new oven. Sorry.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
Burnt hole in microwave
Is the hole actually bigger than it originally was or is it just empty because the rack support got burned up & discarded?
The rack supports / rack holders can be ordered. The part number is WB06X10140 (or WB6X10140) and they're less than $5.00 each. You can find them in stock here.
If you install a new rack support in the hole, then any gap or hole around it can allow grease to accumulate, and that can lead to arcing. But you can seal it safely & easily.
Once the support is installed and everything is squeaky clean and dry, you can apply a small amount of silicone caulk into the gap or hole.
Let it dry it overnight with the door open, then use a razor blade or X-acto knife to gently trim away any excess caulk.
That would be a really good fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
274 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
