Question about Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator
Arghhh...Only 2years old and a bunch of room temp food!!
OK
#1 Light comes on
#2 Digital push button temp control dead - not lit up anymore
#3 No compressor, no fan, nada running
#4 Water works
  • 1 more comment
  • equifax Feb 05, 2008
    Since the LED board didnt light up I ordered a new one in hopes I could save a $100 svc tech fee. Searpartsdirect to deliver this Thurs so we'll see if that does it. In not my wifes gonna kill me for playing mr.fixit while she endures 3 igloo coolers scattered around the kitchen holding everything salvagable we found in our lukewarm fridge/freezer. Thanks!
  • equifax Feb 07, 2008
    Replaced the Jazz Board and still nothing!! Should have bought a $600 GE plain ole plain ole VS. this $2300 cabinet depth POS.
  • Peter Dolid
    Peter Dolid Feb 20, 2014
    Did you ever figure out what the problem was? Did you replace the HV board?
Very simply it is the Jazz circuit board which is also the board with the digital lighting the control board. Any questions hit me up.Ed
Posted on Feb 05, 2008
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Simply put it does not come alive with batteries anymore. need a replacement i think.
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
If you need a remote then try the following or other sites;
In the USA look at; www.remotes.com
In the UK look at; http://www.espares.co.uk
Mar 24, 2011 | Televison & Video
LG LCD '42LG6' TV Remote control seems to be jammed - the TV button on the remote is lit up and won't turn off - now I can't seem to do anything - The actual TV can be turned on and off and we can change...
Special Note:
Mar 03, 2011 | LG 42LC2D 42 in. LCD HDTV
My remote doesnt seem to be connecting with the system. whenever we push a button no light comes on weve tried new batteries and it hasnt work wat can we do
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12976414911881
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
If it works, Great!
If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Feb 13, 2011 | Bose Cinemate Digital Home Theater System...
The freezer is running, and the light is all coming on but it is not freezing the contents in the freezer?
Hi and welcome to FixYa. I am Kelly
If your sure the compressor is running and it is not freezing then there has to be a system coolant leak.
Having said that there are a few things to check:
1. Is the compressor in fact running Y / N
a. Yes = coolant level problem or coolant system blockage
b. Not running = (Possibilites below)
1) PTC / Klixon Thermal overload failure
2) Run capacitor failure
3) Temp control failure
4) Automatic defrost thermostat or thermistor
5) Defrost timer or Adaptive defrost control failure (depending on model)
2. Is the compressor very hot to the touch or room temp?
a. VERY hot = unplug the unit for at least 30 minutes and then plug it back in.
b. ROOM temp = any of the above in 1b items 1) - 5)
3. Is the evaporator fan running?
a. Yes = Temp control is ok Defrost system is probably ok
b. No = same as 2b
With a model number I could pass on a few additional things to do. For the moment use the above.
Thanks for choosing FixYa,
Kelly
Oct 18, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
Gas duet. Mod: GGW9250PWO Ser: MR3604435. Front panel under Status: "Control Locked" light is lit..nothing else works, including Control On button. Dead. Can the dryer be reset??
is the other lights DIM(partially lit)?
If so it could be one of the following.
1.) Intermittent ribbon cables between the control board and the Interface board (one with the buttons) Reseat all four cables.
2.) faulty control board.
3.) faulty Input board.
Nov 11, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a frigidaire sisde by side refrigerator model # FSC23F7TDW. My Temperature control is reading the the freezer & fresh food temp in centigrade. How do I get the Temp display to read in...
Same Guest as above posting this ... By the way, I have a FLSC238DS5 ... I spent 45 minutes on phone w/Frigidaire this afternoon (Phone#: 706-860-4110 Option 1 --> then Option 3). Didn't get anywhere. They say there are 3 solutions that should change it from C to F: 1) In between LED readouts for "Freezer Temp" and "Fresh Food Temp" there is a mode button that is hidden under the plate that you can press w/your finger OR 2) Hold "Fresh Food Temp" Up Arrow Key down, within 5 Seconds press "Freezer Temp" Up Arrow Key 3 times and it should change C to F or vice verse. Didn't work for me so she said 3rd option was to have a service tech come and diagnose. She said there would be a charge. I am not paying to have somebody come here to resolve this issue. That is when I asked her to escalate it to a supervisor which she did. Hopefully, I get a call back & a solution. Stay tuned ...
May 24, 2008 | Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Open Questions:
Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator Logo
145 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
