Question about Mitsubishi CS-27205 TV
TV problem Hello. I have a 13 year old 26" Mitsubishi TV. The screen has started to waver horizontally and is now only about an inch or two. The audio is fine. Is it the picture tube, perhaps.
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
Posted on Feb 03, 2008
SOURCE:
I have an old 36 inch widescreen Philips CRT TV which has been working fine for 7 years until yesterday when the whole screen just went blue with a series of white horizontal lines. The audio is still OK...
Hello
Since there is a blue screen atleast, I don't think that the picture tube is gone. The fault may be either to its chroma IC or video output section. In both sections fault cases, this type of horizontal lines [parellel to each other at about 1 inch or so apart the entire screen] will be seen. Just check the voltages at the three cathode, ie, red, blue and green of the piclture tube. This can be measured at the picrture tube neck card. If you have through knoledge in electronics, have patience and enough tools to do the work, inform me through Fixya. Without these, you can't work on a tv, especially in Philips.
Otherwise, get it checked by any expereinced service technician. OK.
Feb 21, 2011 | Philips Televison & Video
I have a 13 year old Mitsubishi tv which worked perfectly up until today. I am getting a thin blue horizontal line through the center of my tv screen. I have no picture but I do have sound. Can you advise...
The vertical scan module has failed. The tv is easily fixable, but not by you, you will have to call a technician to replace/unsolder some parts. It will cost you around $150 ($25 the parts plus the labor) so must decide if the tv is worth that.
Jul 01, 2010 | Televison & Video
Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Feb 10, 2010 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
While watching my 32 inch lcd hdtv the screen turned dark
Could be some bad caps in the power supply but also the inverter panel.
Aug 04, 2009 | LG 26LG30 26 in. LCD TV
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Mitsubishi WS-48613 No Video
If you have no video and audio then IC9c25 on Sig. Bd.
Jan 14, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Entirely black screen Mitsubishi Model CS40503 SER. 530082
  1. YOU WILL NEED TO CHANGE
  2. Q6c2
  3. Q291
  4. D251
  5. CHECK MOUNTING OF PIP-PCB TO MAIN-PCB
Nov 25, 2007 | Mitsubishi CS-40503 TV
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Intermintent picture
Check the horizontal output transistor this could be damage and causing the problem.another thing is pilot light that cause the screen to light up.since this is a projection t.v.it does not garry a tube.
Jan 19, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
