Question about Sharp 56DR650 56" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel replacement where to get one
Any Idea on where to find a color wheel, for this unit, or a place to get a repair kit for it.
  • lfester Feb 03, 2008
    It was not the right referral of part. color wheel or repair kit, is what I was looking for.
    wrong part # that for a board. color wheel Part # for my Sharp Dpl56dr650. I have a bad air bearring in it.The part # on the ribbion of the color wheel is reads as followed P/N oc-cw7bb-bc017
  • Sharp Master
  • 8,617 Answers
The part number is 9NK3797086200 it is available at vance baldwin here is a link.
http://www.vancebaldwin.com/products/?SHA&start=301
Posted on Feb 03, 2008
  • 80 Answers
If you want to buy the color wheel only let me know i have new original ones in stock
http://www.palmbeachav.com/Contact_us.html
or email me at nipper00@gmail.com
sorry but my fix is $1460.05 less plus shipping :)
cost $169.95 + 10 for shipping
thanks
scott
Posted on Jun 10, 2008
Need to clean color weel
Hello
To clean the colourwheel do the following.
Soak cotton swab in denatured alcohol
Using a circular motion, swab gently one color area at a time
Use dry swab to remove film build up.
Repeat to ensure the wheel is thoroughly cleaned
DLP color wheels need to be cleaned approximately every six months to a year, if the environment they are placed in is smokey, greasy or dusty. Sometimes, restaurant owners or places with high customer traffic will find that their TVs are experiencing picture degradation due to the smoke-filled rooms or greasy fumes from kitchens. There is no need to replace the color wheel but just to do a quick cleaning to save money on replacement parts. Even if you have your TV at home, your DLP color wheel may require a cleaning occasionally to provide clean picture quality.
Mar 27, 2011 | Sharp 56DR650 56" Rear Projection HDTV
When i turn my tv on it sounds like a high pitched wine...is it the motor?? Still turns on no picture quality issues just a loud noise that accompanies the picture
Thats your Color wheel But acorrding to what I researched you have to Replace the whole optical Module part# 9NK3797086200 which is optical module,light Engine & Colorwheel Encompass Parts do not have it in stock but they List its Price $1,930.00 core refund $1,030.00 cost of total replacement is $900.00 you can call them to find out 1-800-638-3328 or try UED 1-800-648-6657. See if you can just replace The Color Wheel itself because that is what is Bad! OR are you better off to just replace the whole unit!
Dec 03, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Ok, so i thought i could fix it, now i need help. Problem 1. My tv was buzzing and sometimes the color was weird when you first turned it on. Then after about 30 min. all was fine. Well one day it just...
When the Color Wheel Motor does not turn any more the set will shut down. The only way to my knowledge to fix it if this is what is happening is to replace the Optical Block. It consist of the Color Wheel and Optical Path as one unit and it is expensive. I estimate 700.00 to 800.00 maybe more. You could try to price it through Encompass Elect. 1800-638-3328.
Hope this helps,
Skyassoc
Dec 02, 2009 | Sharp 56DR650 56" Rear Projection HDTV
I have a Sharp 56DR650, red power light turns off.
Engine block(color wheel) needs replacing approx $650 total
Aug 09, 2009 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56dr650 Dlp colorwheel for Mike miaer
I have a Sharp 56dr650. The color wheel bearing failed. Sharp cares not for its customers and won't even respond to my pleads for help in obtaining the replacement. So, with that said, I went to ebay and bought a vizio color wheel (Omega TV in Hollywood, FL). Color wheel is incorrect and colors are all blue as is, so I pulled the color wheel off and did the same from the old one-BIG note, the wheels are glass and fragile, DO NOT BREAK the old color wheel! I viced the old bearing and carefully worked the shaft out of the bearing (it is snapped into the bearing). The vice distorted the old bearing but it was trash anyway. The new bearing, I broke the new color wheel off and viced the shaft. I then pulled the old bearing from the wheel. I then carefully push the old shaft and color wheel into the new bearing (you will know when it snaps in place) asserting preasure ONLY on the metal center hub with my thumb. I had to file a new slot on the cast housing as the ribbon connector is about 1/2 inch shorter on the new bearing. I installed and it all works great!!! Saved from tossing a $2,000 plus tv out! SHAME ON SHARP! Never buy another Sharp product!
Feb 15, 2008 | Sharp 56DR650 56" Rear Projection HDTV
I have the color wheels in stock let me know if you need them
Contrast
These set have a problem with the color wheel, when it starts to fail it will do what you describe. The bad news is Sharp will not sell just the colorwheel, the sell the entire light engine for $1200.00 ond as of today I still have not found a replacment colorwheel that will work for this set
Dec 16, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp DLP No picture
i have a 56DR650 and it does them same thing. It is still under warranty but where i bought it, they said they can no longer fix it so they are giving my money back. the problem has to do with the color wheel inside.
Oct 31, 2007 | Sharp 56DR650 56" Rear Projection HDTV
Sharp 56DR650 56" Rear Projection HDTV Logo
905 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
