Question about Kenmore 40042
Washing Machine Capacity
I have a Kenmore 40042 which was a gift and slightly used when given to us 4 years ago. The machine is broken and needs an inner and back half outer tub (that is what was written on the work order). The repairman said to get a new machine because fixing it was going to be very expensive.
Since it was a gift, we are likely to buy a new machine. Our family is larger now and we need a bigger machine.
1. How large was the capacity of the 40042? 3.2CF? We need something larger
2. What models are recommended these days? We've seen some LG's at Home Depot and wondering about those. the LG 0642 seems attractive.
Eric
    Novelist:
  • 130 Answers
Ovenon what you what is 18lb to 20. Bosch is 18, LG 18 & 20 (depending on model), Whirlpool is 18 however I hear they have a 20 now as well. The big think to remember is that machines will break. Make sure you can get service in your area before buying. 2nd don't go by looks, but will it do the job I want to do, looks don't clean laundry. If LG is what you are really thinking of, call the local servicer and get his opion. If he works on lots of them, well there is the service history in a nut shell. Note, what propably took out your old machine is too much high sudsing detergent. Water will not affect the rear bearings, however detergent is designed to remove the bearings grease. Hope this helps.
Posted on Feb 04, 2008
Washer capacity of kenmore 4906 4907 ie 5.0 cu feet
The Kenmore 592-4907 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
The Kenmore 592-4906 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
This is the Specs website despite the title :>)
teachmefinance com
Mar 24, 2017 | Kenmore Washing Machines
Spin cycle not working,clothes are very wet at end of wash
I believe that there is a switch on the underside of the top of the machine. It would be located back towards the middle of the machine. If this switch is out, it would cause that problem. It is fairly simple to replace
Jan 26, 2011 | Kenmore 40042
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machine Leaked but seems ok now.
likely it was overfilled - and caused an unbalanced load that may have shifted the tub - allowing the gasket to leak.
May 26, 2009 | Kenmore 22422 Top Load Washer
Broken washing machine
2.5-4years old. They started making them 4-5 years ago
May 15, 2009 | Kenmore Washing Machines
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Won't drain
Check the lid switch it may be broken
Dec 17, 2007 | Kenmore 40042
Washing Machines Logo
188 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
