Question about Sanyo DS24425 24" TV
Stereo speakers to television.
I don't know how too hook up my stereo speakers too my television so tv
sound comes out from stereo speakers.
  • 89 Answers
Please check your tv for any RCA jack labelled "Line Out". The will provide the signal taht you need to connect to your stereo system's Line In jack. Also, to get the Stereo output that you want, yur TV should have a pair of Line Out jacks (color coded red and black or red and white)
Posted on Feb 04, 2008
Can't get sound thru my stereo and stereo speakers
If it is just the sound from the computer then if you have windows look for the little speaker icon in the bottom right corner of the screen, right click this, select "Sounds" then select playback (while connected to the tv) and chose the tv as the output device (set to default).
If on the other hand the issue is with the tv at all times then try going into the menu settings of the tv and looking for the various sound options. Possibly the remote control will have an audio button that scrolls through various audio options (two circles followed by roman numerals?).
Hope this is of some help.
Nov 22, 2013 | Televison & Video
Connecting to a video game console
Hooking your PS2 Up To your Stereo
Just got a PS2 and trying to hook it up to your TV, stereo or both? Here are instructions to help you get everything working smoothly.
First, some basic cable definitions. These are pretty much standard for ANY system or stereo you ever get, so it's good to learn them.
RED CABLE - right channel for stereo sound (get it - Red Right?)
WHITE CABLE - left channel for stereo sound
YELLOW CABLE - video signal
Your PS2 plays games and plays DVDs. So it is generating signals that go OUT of that box. You want those signals to go IN to your TV. The most simple way to do this is to simply plug them into your TV, if you have no stereo system hooked up and nothing else attached to your TV. Most TVs have stereo left in, stereo right in, and video in. Most in fact have them all color coded with the above colors. So all you do is plug the cables in and turn the TV on. Some TVs have to be set to channel 2 or 3 to know to take the signal in from the Video In line, but your manual would tell you if that was the case. Here is a diagram of the straight connection.
I would really recommend hooking a stereo system into your TV, though. The PS2 has INCREDIBLY stereo sound and you really miss out on a lot if you just have the sound coming out of your TV speakers!! Especially if you play DVDs through your PS2, you want that sound coming out of the stereo system. So in this case you would send the video to your TV, so your TV can show the picture. You then send your audio (sound) to the stereo, so it can play the sound. Most stereo systems have multiple input spots so you can plug in your CD player, your tape player, your record player, etc. So just choose an input spot that isn't taken yet. Here's an image of that connection -
So let's say you don't have a tape player and therefore plug the red cable into "Tape Input R" and plug the white cable into "Tape Input L". To make the sound play, you would now press the "Tape" selection button on your stereo so it played the music coming through the tape channel. Since that's where your PS2 is plugged in, that is the sound that will come out of your speakers.
Jan 29, 2008 | TruTech PVS31170S1W 17 in. LCD Television
When I connect the tv to the stereo receiver the sound still comes through the tv in addition to the stereo speakers.
This condition sounds normal, often you need to turn off the speakers in the TV, via menu options on the TV.
Aug 17, 2011 | Hitachi 53UWX10B 53" Rear Projection...
No sound
Go to menu options and turn speakers back on, unmute and turn volume up.
May 16, 2010 | Hitachi 51SWX20B 51" Rear Projection...
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
I have hooked by two bose 161 speakers using 14 gauge speaker wire (about 8 feet) to sony str-dg720. But I get absolutely no sound from the speakers. I have hooked the speakers to port A set of input...
You gots ta isolate the problem.  Disconnect the speakers and hook them up to a stereo you know that works.  If you don't hear sound coming out of the speakers, then you know the speakers are fu.k.d up, so you need to look on the speakers to see if there is a fuse that is blown that needs to be replaced.  If you got sound coming through, then disconnect them and hook them back to the original stereo making sure you got a good connection and all the wires are in good and tight.  Then turn your stereo on and go through the various channels like Tuner, Tape Deck, Aux, and DVD to see if you get any sound.  Also turn the volume knob up. If you don't get any sound after all this, you know there is something wrong with the stereo your using.
Oct 29, 2009 | Sony STR-DE685 Receiver
Sound through stereo
that is very easy, just get an RCA cable, the one with red/white and if your tv has audio output connect the RCA cable to it and the other end to AUX into your stereo, change your input selector on the stereo to AUX every time you want to litsen through stereo speakers.
good luck
Jun 18, 2009 | iLO 3200 32 in. LCD Television
Getting stereo speakers to work with flat panel tv
if you hook the low-level audio-out from the tv to an input to the stereo unit, whatever you play on tv will send audio to surround/stereo reciever unit. look on back of tv for red &white AUDIO OUTPUT terminals. plug red/white audio cables from tv to the back of your stereo & plug into audio input of an open source on stereo (tv/video,aux. in,etc.) good luck!
Mar 09, 2009 | Televison & Video
Toshiba 3387db has stopped working
did you hard wire the stereo directly to the TV's speakers or audio circuit? IF thats what you mean, bad idea, you probably blew the audio amp which can hold down the power supply and cause the tv not come on
Apr 22, 2007 | Toshiba 3387DB TV
RCA Audio Out not working?
You don't say whether you're successfully getting sound out of your stereo or not. I'll assume for the moment you are. Still getting sound out the TV is perfectly normal - RCA plugs have no mechanism for automatically disconnecting the built in speakers (in this respect, they're different from a headphone socket). Solution should simply be to press the mute button on the TV remote - although this will silence the TV speakers, you wouldn't normally expect it to affect the RCA output (failing that, just turn the TV volume control right down). A.
Apr 21, 2007 | Akai LCT2701TD Television
Sanyo DS24425 24" TV Logo
239 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
