Question about Brother SE-270D Computerized Sewing Machine
Need help putting part on
I am new to sewing. I have a Brother 270d. I went to load my upper thred and I believe the thread guider came off. Tension too high? How do I put it back on?
  • jackie124 Feb 10, 2008
    I returned my machine and bought another. Thanks for the advice, though.
Mine did the same thing within the first week I had it, and I left it off. I have had mine serviced, they attatched a new one, but the servie cost 125. Good Luck!
Posted on Feb 10, 2008
Why is my Brother SQ9185 Sewing Machine thread bunching up on the back side of the fabric?
That is called thread nesting or bird nesting. Usually it is because it is threaded incorrectly (sometimes the thread jumps out of a thread guide or the take-up lever), the upper thread is not seated in the tension disk, or the upper tension is incorrect.
First thing, install a brand new needle.
Second, remove the upper thread, RAISE the presser foot and rethread from the beginning--make sure the correct thread path is followed.
Third, check that the upper tension is set at the midway point between high & low number.
Test. Adjust the upper tension as needed. Re-test. Tension is correct when the upper and bobbin threads meet in the middle of the fabric.
need elp with tension on singer cg550
Apr 07, 2016 | Brother Sewing Machines
THREAD POPS
Is it perhaps poor quality thread? Avoid old or bargain bin threads,. Also, might try a brand new needle of the type suitable for your thread and fabric. Have you verified the needle eye is the correct size for the thread?
Understanding Thread Tension Threads
All About Needles SCHMETZ Needles
Jan 31, 2018 | Brother SE-270D Computerized Sewing...
I have a Brother 750D innov-isi think he tenchion
If the thread is pulling through the top of the fabric slacken off the top tension to about 4 and tighten the bobbin tension slightly by turning the screw on the bobbin case about a quarter of a turn clockwise and test.
Apr 06, 2010 | Brother SE-270D Computerized Sewing...
The thread is bunching underneath the material and the stitching is very loose
Usually that is due to insufficient upper tension OR a thread routing problem. Make sure when the presser is lowered that the upper tension activates. I think if one had really thick material the tension MIGHT not activate because the lever would not come down far enough.
Check that the needle is in right... usually the long groove is closest to the operator.
Jan 18, 2010 | Brother SE-270D Computerized Sewing...
Thread wad on undersurface
machine not threaded properly? wadding thread underside means upper thread does not have tension.
Jun 30, 2009 | Brother SE-270D Computerized Sewing...
Bobbin thread pulls to the top with all but Brother brand
Your machine was designed to work with the Brother brand of bobbin thread. Any other thread will cause tension issues. If you want you machine to work with another brand of bobbin thread I suggest purchasing an additional bobbin case and have it calibrated for use with the other brand of thread.
Mar 17, 2009 | Brother SE-270D Computerized Sewing...
Pure problems
That series machine has had a LOT of issues with the "automatic" upper threading/needle threading mechanism. I believe that is where the issue is coming from. I would take it to a authorized Brother dealer and they should be able to diagnose. Many things can interfear with the top tension on that mech. and a good tech will be able to help.
Dec 23, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
60 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
