Question about LG VX5300 Cellular Phone
No audio I have absolutely no audio on my phone. I can't here a ringtone, keypad, the speakerphone button doesn't work. It just stopped completely.
  • robert walter May 16, 2008
    My LG 5300 just wont call out or when some one calls me they do not hear it ring. The other day, a dime got stuck in the slot where the charger goes and it drained th battery. I recharged it and no probs until three days later. It shows the little transmit signal but nothing.. any deas?
Wife had similar problem. local verizon store technician asked her if she used a headset - when headset is used external audio is muted - seems, somehow, the phone was "stuck" in headset mode even after the headset had been removed. solution was to re-plug in the headset and remove is slowly. hope this helps.
Posted on Jun 20, 2008
  • samdfh Nov 28, 2011
    I have the same problem with my samsung jet. My solution, which ALWAYS works, is to swith off the phone and switch it on again. Having said this, the jet is a joke and couldn't have been worse. I remember it being advertised as "smarter than smarphone!"....smarphone my ***!!!!
Want to know if cs6319-4 VTech cordless phone has bluetooth capabilities?
No........
CS6319-4 Features:
  • New DECT 6.0 Technology
    - Interference Free Communication
    - Increased Clarity / Enhanced Security
    - Wider Range / Network Friendly
  • 1.9GHz Cordless Phone
    - Dedicated for Cordless Phones by the FCC
    - 30% Battery Life Increase Over 5.8GHz
  • Caller ID / Call Waiting
  • Expandable Up To 5 Handsets
  • Wall Mountable
  • Handset Speakerphone
  • Backlit LCD Display
  • Backlit Keypad
  • Name / Number Caller ID Memory
  • 100 Station Phone Directory / Dialer
  • Conferencing
  • Selectable Ringtones
  • Handset Volume Control
  • Handset to Handset Intercom
  • Call Transfer
  • Last Number Redial
Jun 03, 2011 | Vtech Lands Phones
Blackberry 8320 has absolutely no audio out. Can
Please follow the troulbe shooting steps given below.
press menu key, select profile, Under that select advance, press menu key, click on edit, select phone, you will get all the option, Click on ringtone, select Browser, under that select music you will list of songs, select anyone those songs for you're ringtone you will be able to hear the ringtone for you're selected songs.
Oct 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Moto q9h speakerphone works, can't hear ringtones or any sounds
hold down the scroll wheel on the left side while in windows media player, hold it down till a volume bar comes up, make sure that its all the way up by rolling the wheel up
Jul 17, 2009 | Motorola Mobility Moto Q
My blitz's speaker phone wont work. and the open/close, on/off, and ringtones, wont work... help! ive gone thru all sound settings and everything is "on" i can hear my calls thru the regular handset...
Try these couple of things:
The speakerphone feature lets you hear audio through the speaker and
talk without holding the phone.
  1. To activate the speakerphone while in answering or calling modes,
    press the Navigation Key to the right.
  2. The phone returns to normal (Speakerphone Off) after ending a call
    or when the phone is turned off and back on.
To adjust the ringer, key tone, voice call and speaker phone volume levels:
1. Press left soft key [MENU] (7) (1) (2).
2. Select the type of volume you wish to adjust.
3. Select the desired volume level.
4. To confirm, press OK.
Let me know if this works for you or if I can help you with anything else.
JimmyC
Jun 13, 2009 | UTStarcom Blitz Cell Phone
Speakerphone
When you have an incoming call, or when your making a call three buttons should appear. One says Spk. On , one says Mute, and one says Keypad. Just touch the one that says Spk. On, and your speaker should be working.
Mar 16, 2009 | LG Vu CU920 Cellular Phone
Ringing sound, speakerphone, completely lost
Either bad speaker or audio amplifier. Warranty.
Feb 18, 2009 | RIM BlackBerry Curve 8310 Smartphone
Keypad doesn't work
I'm thinking this may be a failure of the phone that is not related to the ringtone, unless there's such a thing as a virus that can nuke a cellphone. I've had two RAZR phones die on me (neither in this method), but anything with a keypad such as that on the RAZR will eventually have trouble. Stop into your provider's store and see if it's something they've seen and know how to correct.
Jul 29, 2008 | Motorola Mobility RAZR V3
Keypad stops working on handsets
After you remove the battery and the two obvious underlying screws, you will need to pop the two halves apart. This takes some force and you may break some internal plastic clips, but you have no choice. There are approximately six internal plastic clips, so don't worry about breaking one or two. The screws hold it together securely anyhow. Then there are 5 more little screws to get the back PCB off. Then use nail polish cleaner and q-tips and clean the contacts on both the rubber pad and the PCB.
The keypad will work like new again - magic.
Jan 19, 2008 | Vtech VT-2431 Cordless Phone
Handle Speaker phone stopped working
I'll assume this is on the base station portion. You can try unplugging the power while the phone is in the base, wait a minute, then plug back in. If that has no effect, I'm afraid you either have a failure in the keypad or in the electronics. To diagnose a keypad failure in the base, you'll need to disassemble the base. You'll find each of the rubbery keys momentarily connects two traces on the keypad circuit board when you press a button. You may also find the keypad fouled with dirt, liquid, etc, which could be a likely cause of failure. You can try manually shorting the two traces where the SP/Phone button would press and see if you are able to activate the speakerphone/dialtone. If that works, then carefully clean the keyboard circuit board and the rubbery keys. If that does not work, I conclude you have a bad keyboard circuit board or other electronics in the phone are bad.
Dec 16, 2007 | Panasonic KX TC1713 Cordless Phone
Phone stopped ringing
It seems yourphone has a silent mode.
It happened when you accidently press # button too long.
Try press the # button again!
Aug 18, 2007 | Samsung SGH-T519 Cellular Phone
LG VX5300 Cellular Phone Logo
166 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
