Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Netgear wireless wpn824
The router is successfully setup and I can connect to the router wirelessly. However, I cannot connect to the internet. I can connect directly through the dsl modem, but not through the router (wireless or lan cable)
  • sexylisa Feb 15, 2008
    can not get my laptop to working with my wireless router
  • sawhite22 Dec 30, 2008
    Is the NetGear WPN824 compatible with Windows Vista? I am having difficulty connecting to my new computer.
  • 56 Answers
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Posted on Feb 03, 2008
6ya staff
SOURCE:
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
I need to find a ssdi code on the netgear rangemax wireless router so i can go on the inter with my dsi don't wont to use internet i just wont to find it on the...
For this you will need to open the setup page of the router.
Do u have any computer connected to the router ?
If not then you can connect one of your computers to the router.
Access the routre setup page. under the wireless settings you will find the SSID of your network.
SSID is nothing but the name of your wireless network.
You will need to check the wireless settings of the router..
Click Here for more information about the routers and network
Jul 11, 2010 | NetGear RangeMax WPN824 Wireless Router
I can't connect to internet wirelessly, though my
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 16, 2010 | NetGear RangeMax WPN824 Wireless Router...
Everytime I want to use the internet I have to plug in the ethernet cable from the router- WPN824- and go the the 192.168.1.1 address and setup the wireless setting. Then I can disconnect and use my laptop...
Netgear routers are notorious for this. The firmware on the unit just loses connection. In order to fix this, you have to make sure that you have the latest firmware.
There are several version of your unit. go to the following page and download the firmware and update it to the latest non-beta release.
http://kbserver.netgear.com/products/WPN824.asp
Aug 04, 2009 | NetGear RangeMax WPN824 Router
Netgear WPN 824 Low wireless signal
If you can access the router setup page, the best way to boost the signal is to change the wireless channel on the router setup page to a higher channel so the signal will be strong...
May 27, 2009 | NetGear RangeMax WPN824 Router
Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Apr 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Lost setup DC
The router is compatible with any operating system. You don't need to use the CD that came with it to setup the internet connection. Just open the router's setup page by typing http://192.168.2.1 on your browser. There you can see the automatic setup.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Am i able to still connect
no cd required - search on the internet for connection instructions
Feb 01, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need my passphrase for my netgear wpn824 wireless router
Are you trying to setup your router? If so..
Here is a list of Netgear WPN 824 Models. :) USERNAME PASSWORD
Netgear WPN824 v2 (Netgear Firmware) admin password Netgear WPN824 v3 (Netgear Firmware) admin password
Netgear WPNT834 (NetGear Firmware) admin password
Jan 07, 2009 | Computers & Internet
Is the smart setup (that is automatic setup) does not work, call your internet provider for the exact details (unless you have them) and do the manual setup.
You will save time.
Nov 14, 2007 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
240 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
