Question about Garmin StreetPilot C330 GPS Receiver
I love this unit!
I've owned this unit for two years now with absolutely no problems. I brought it in from the garage yesterday and now the system turns on for a second then shuts down to nothing. I plugged it in to charge overnight but still nothing. I can't find my user manual. Some speak of a reset button. Would that help or would it remove all of my maps? Any suggestions?
  • 504 Answers
Resetting should not remove your maps. Have you purchased new maps since you bought the unit? Have you tried charging the unit via the computer, or just with the car charger. Sometimes charging on the computer can help.
Posted on Feb 04, 2008
How do I fix a door that opens on its own?
It is likely someone has the same type of remote and is trolling the neighborhood searching for a garage to clean out. Older openers without the rolling code feature are susceptible to this
May 26, 2013 | Chamberlain 3/4-HP Whisper Drive Plus...
Were is the outake intake and 10 amp fuse sited .cheers
Same quest I had. So, with flashlight, look inside the 3 prong AC receptacle. It's subtle, but on the lower inner "shelf" of receptacle can pry outward toward you with jewelers or thin standard screw driver. Fuse holder and fuse popped out with a hard pry. Does it look burnt? Mine ohmed out okay, so must be some other problem. 8 sec of charge light when 1st plugged in; then no light. Works plugged in but not unplugged. Idled a year in the garage. My fuse was 750mA 250 (in America, 110V)Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off. -Cheers
Dec 23, 2012 | Alesis TransActive Mobile PA System...
My Alesis Transactive Mobile PA is not working. The charging light illuminates only when initially plugged in, then turns off. I'm thinking the battery may be dead even though I've only used t
Mine works when plugged in, but dead when not plugged. Found fuse, subtly hidden in lower part of AC power receptacle; pried out with small screw driver. Looked good & passed ohmmeter check. I loved the beast when it functioned. It spent a year in the garage; it didn't work when I brought it in. Charge light on for 8 seconds after plugging in, then off.
Sep 15, 2012 | Alesis TransActive Mobile PA System...
I bought a weed eater gti25t at an auction. The pull mechanism will not engage. Is this unit fixing?
There are quite a few different types pull start engagement mechanisms out there. As such, you would think replacement parts would be more readily available at the larger chain stores that sell the bulk of small engine powered devices. Not so.
I'm lucky to have found an excellent local small engine repair shop that keeps a nice variety of parts in inventory. It's a Mom and Pop place called Mr and Mrs Chainsaw. You gotta love it.
I brought a weedeater in to get parts for a similar problem to yours. Keep in mind, I'm a tech, I do ALL my own repairs.
The cost of the fix in parts and labor to replace the grab ears on my Husquavarna was so ridiculously low that for the first time I let someone else work on my equipment.
Is your device worth fixing? Absolutely.
The repair you need is straight forward and intuitive. The cost will be your time finding the parts.
If you can find your own Mr. Chainsaw? Doubly so.
Best regards
Mike
Aug 15, 2010 | Poulan Garden
Sometimes my garage doors opens on its own,,can
You need to change the code in the remote and inside the receiver in the motor body. There should be little switches in both units that must match setting.
Nov 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
No power
Could be some kind of fuse it the unit.
Aug 17, 2009 | Frigidaire FAC107P1A Wall/Window Air...
RCA RT2600 Speakers stopped working.
I bout mine used an it has absolutely no problems you probably got one that they knew wasnt really working in the first place.
Jan 25, 2008 | RCA RT2600 System
Garage door opens
Do you have the option to change the electronic codes on your garage door opener system? My father-in-law had the same problem a number of years ago. He had not reset the code (equivalent to the combination on a lock) from the equivalent of 0-0-0 (which his unit shipped with). Turned out that a neighbor (or neighbour - in Canada) had the same /similar unit and when the neighbor opened 'his' door, my father-in-law's door would also open. You don't have to see the person drive by - it can be the neighbors behind you as well. You may find a solution by determining if you can change the original electronic code to a different one of your own choosing.
Hope this helps.
Dec 31, 2007 | Sears Craftsman LiftMaster Chamberlain...
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
