Question about Kenmore 22313 Bagged Canister Vacuum
How to open case??
This may not be a 22313 unit, but I didn't know where else to file this request.
I have an old Kenmore canister with a stuck power cord retractor, so I need to open the main case (where all the goodies are). I don't know the model number because I had to replace a cracked bottom clamshell a few years back and the replacement doesn't have the model number plate. (I wrote down the model number then, but of course I can't find it. I think it's written INSIDE the clamshell.) All the canister says on top is "Powermate 4.1". Here's a photo.
I can pry out the corners marked "A" and that end of the cover starts to come off. But the corners marked "B" wrap around the bottom of the unit and I can't figure out how to pry them off without cracking something. How do you get the cover off of the motor compartment?
  • 1 more comment
  • cstrathmeyer Feb 04, 2008
    Sorry, no screws evident anywhere. The plastic clamshell must pop apart somehow, just a question of how and where.
    --Carl
  • cstrathmeyer Feb 10, 2008
    Located the model number: 116-264-1082. The official Kenmore exploded diagram does not show any screws for assembling the case parts!
    Found out how to open the case: Just have some courage and pry out at points A and B on both sides. Pry on points A and B at the same time on a given side until the clips molded into the top case wall release from the vacuum body. Then do the same on the other side. The top cover just lifts off, exposing the motor and cord reel.
In an unsuccessful attempt to swap out the motor in a 12 Amp turquoise modeI curbed b/c some nut had Gorilla Glued the wheels on) with the motor from my 11 Amp maroon one with a broken (poorly designed button covering the switch that would turn itself off and on erratically so fell victim to inordinate persuasion) I was finally able to pry the top rear bonnet off my 11 Amp maroon model by aggressively flexing a long (for leverage) wide screwdriver at points A on both sides.
However, removing the back bonnet over the 12 Amp turquoise canister pretty much ruined it b/c there were two inaccessible screws inside the back which I broke the housings for but could possibly superglue if the motors had been compatible.
Posted on May 29, 2008
    Scholar:
  • 103 Answers
I don't know this vacuum personally, but i'll take a stab at is. You're off to a good start prying around. There is most likely a coupld of screws holding things together somewhere. Check around the bottom and sides for holes where phillips screws may be lurking.
Hope this helps. Please rate this accordingly.
Posted on Feb 04, 2008
Cord is stuck and and will not go back in
Many times the spring that rewinds the cord slips out of a notch or just plain breaks. You'd have to take it apart to find the answer. It's not difficult. The screws to remove the cover are inside the bag compartment and under the buttons.
Good Luck!
Feb 02, 2013 | Kenmore 22313 Bagged Canister Vacuum
A piece of string / cord has wrapped around my Kenmore spinning brush end on the 12 Amp Power - Mate. How is the best way to get the cord off?
Cut the string with a knife or scissors and pull it off. You can turn the brush manually to ensure you get it all.
Oct 03, 2010 | Kenmore 22313 Bagged Canister Vacuum
Kenmore Powermate power head not working
I've got the same problem. Try checking out the electrical connection where the hose attaches to the canister. The hot male terminal is corroded and the female socket is burned out. Its an unfortunate design flaw that every time you open the vacuum to replace the bag the electrical connection disconnects and reconnects. Not sure if I can find replacement parts for a 10 year old vacuum or if a home-made re-wiring job is in order. Will find out tomorrow.
May 30, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Jun 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Rollers not spining on my kenmore canister vac.
Particles of the failed belt may be  trapped in the bearings which, if I remember right, aren't very well protected.
I'd remove the rollers, slide the bearings off (if they do slide off) and blow them out with a compressor or saturate them with WD-40 and turn manually until they are free again.
Jan 15, 2009 | Kenmore 22313 Bagged Canister Vacuum
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmore Progressive Canister w/Hepa Filter
May have a problem with the motor protector or the motor itself. The motor thermo protector will shut the motor off if it senses it getting hot. So it could be bad.
Apr 13, 2008 | Kenmore 22313 Bagged Canister Vacuum
Kenmore 22313 Bagged Canister Vacuum Logo
470 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
