Question about Fujitsu P55XHA40US 55 in. Plasma Television
Video 1 stuck on "Welcome. Powering up..." screen
On my Fujitsu flat screen, I can watch a DVD on Video 4, but I can't watch cable on Video 1 because when I go to that screen there is a message saying "Welcome.  Powering up..."  If I switch off the TV and then back on, the message comes back.  Can you suggest how to get past this problem?  Thanks.
  • 2 more comments
  • mat_99 Feb 03, 2008
    when i switch on the TV, it says "Now Loading..." the way it normally should, but then the screen comes up saying "Welcome. Powering up..." and it doesn't change at all. it's been the same for the past hour
    Still not getting past the "Welcome." screen
    it was working last night, but not this morning. the power went out in our neighborhood in the middle of the night for a few hours. maybe that has something to do with it? when the power went back on, could the surge have damaged something?
    the flat screen is plugged into the wall. but it is working, since i can use video 4. what isn't working is the video 1 input...
    Genius:
  • 3,422 Answers
It is a harddrive problem,perhaps a problem with "unclean" current or an intermittent power supply. Use of a line current leveller and/or a UPS (uninterruptible power supply) might be in order..
You can check the output from the PS to the drive. The red/black is 5V and the yellow/black is 12V. The tougher issue is the test from the PS to the motherboard, which is not really plausible.
If your friend is willing, you might try his/her PS in your HR10-250 (or vice versa) to see if you can learn anything that way.
You can also check the below link if it helps u out..
Click here
If nothing works u have to go for a replacement..
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 03, 2008
    Master:
    Sergeant:
  • 440 Answers
Try new cable on the tv from the dish box ect to tv
  • Anonymous Feb 03, 2008
    oh yes do u have it pluged in directto wall ?
    ya u def need to buy monster power strip u can not plug thes ehi end tvs in the wall direct storm an dyour done so touchy ok no protection for u also monster cable makes one hd700 u shoudl plug into stage 1 clean power cuse in usa alot bad power up down that kils hd tvs big screens all the time ok so best u get it on a strip never direct in wall
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well thats some kind of tricky :(
and how much time do it get? when say powering up? did you check that?
6ya staff
SOURCE:
How to get video from dvd to tv
Use HDMI wire if you have that option than simply tune TV to HDMI 1 or HDMI 2 etc depending which one you connect it to .
OR. analog ( R C A ) cables analog. Output from DVD player to imput tv """ red is right white. Is left sound. Yellow is video pay attention to where you are plugging on TV.video 1 or 2 or 3 Since you will have to go to ( video. Or imput ) on your TV to access the DVD player. Another words your cable box is a TV imput . You're doing is also a TV imput You have to tune it to be able to watch it
Feb 16, 2015 | Universal 40-42 Inch Flat Screen Panel...
Frozen screen
Unplug your cable box from the wall outlet. Wait 3 or 4 minutes and plug it back in.....TV should now be normal.
Sep 06, 2014 | Televison & Video
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
No video signal comes on screen when watching movies and playing games in video 1 signal
Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | Toshiba Televison & Video
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    How do you connect a fujitsu p42vca30eh to a BT Vision box? Which cables are needed? Thanks Emma
    You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
    Mar 02, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
    Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
    Hi and welcome to FixYa,
    Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
    • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
    • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
    • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
    • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
    • the other pair to Yamaha's LD/TV L & R;
    • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
    • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
    • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
    • the other pair to Yamaha's VCR 1 IN L & R;
    • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
    • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
    • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
    • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
    • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
    The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
    dd46b75.jpg or
    27340be.jpg or
    Good luck and thank you for asking FixYa.
    Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
    Turning On and Off
    Is your panel actually powering down or is the back light going on and off? That would be a more serious issue but let's try the simplest thing first. Make sure your Remotes Power button isnt stuck down. I have seen this happen before and it will just keep sending out power commands toggling the set On and Off.
    Take the batteries out of the remote and see if it continues to do that. Sometimes the button pads get stuck down.
    Jan 06, 2010 | Fujitsu Televison & Video
    Fujitsu P55XHA40US 55 in. Plasma Television Logo
    103 people viewed this question
    Top Fujitsu Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
