I've just accessed my admin settings for a Dynamode router BR 6004W G2M in order to change the channel from 1 to 13 to see if it reduces WIFI dropout to my ipod touch.
When I accessed the admin, the remember password box was ticked and I got straight in.
The password box is no longer ticked and I cannot remember the password. How do I reset it?
The following procedure(for most of routers) restores the factory default settings(OBS you will loose all the changes you have done to the router!) and resets the factory default: Username: "admin" and Password: "admin" or "password" (not sure which because it is mensioned differetly in two places!) too!
Try finding a hole in the back or under the router (may be marked RESET) . disconnect from the wall outlet(adapter) wait 5 minuts, use a paperclip to push the hidden reset button inside the RESET hole. while holding down the RESET button connect the adapter then release the RESET button.
more info:
http://www.dynamode-drivers.com/index.php?option=com_content&view=article&id=68:br-6004w-g2m&catid=35:routers-cable&Itemid=53
Wish you success!
The only way around this is to do a hard reset. This will put it back to factory defaults and you will loose all your settings and will have to set it back up from scratch like a new router. Here is how you reset it.
Hard Reset
Take a PIN and hold down the "Reset" button on the back of the router,
HOLD IT until the CPU light goes out, then comes back on (Approx. 10 - 15 seconds), then release.
All the L.E.D’s should go OFF, then come back ON.
Leave the Router to stand for a few minutes, for the reset to take effect.
