Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n CX13A011 13 GB Hard Drive
Problem for Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n CX13A011 13 GB...
Harddrives
By lilrob0520 on Feb 03, 2008
I was wondering how to erase everything off a harddrive
Clarification Request
Posted by TecniklyNuts on Feb 03, 2008
Is this the only hard drive in the computer?
Solution #1
posted on Jan 03, 2009
Not Rated)
dutchietoo
Rank: Guide
Rating: 85%, 1 votes
get onto the net ,--go to " dban.org' download the program and use it ,will erase the whole disc,another good one is go to pc world.com ,download secure eraser , use it this one,as is easier to use as, no floppy involved.good luck
Was this helpful?
Yes
No
Solution #2
posted on Feb 03, 2008
Not Rated)
xMadx
Rank: Wiz
Rating: 80%, 78 votes
  • Firstly this is an easy less painful way to do this and it works 99% of the time.
  • Secondly if you do not know how to do this - DON'T, it can be an expensive screw up if you do not know what you're doing !!!
  • Thirdly we are going to slave your hard drive to another PC so we can format the drive. If you are unsure about how to slave the drive to another PC - DO NOT ATTEMPT THIS, GET A PROFESSIONAL TO HELP YOU.
  1. Remove the left & right sides of your tower by removing the four screws at the back along the side of the panel
  2. ( all screws shown as red circles with lines in them ) The yellow circle highlights where the hard drive came from and there should be screws on both sides ( we hope )
  • This image shows the side panel off with the hard drive partially removed.
  • Pay attention to what goes where ( you will need to remember this later ) - Label the leads if needed.
  • Carefully unplug the leads from the back of the hard drive.
Now here is the important part, if you don't know how to set your drive as a slave - GET SOMEONE WHO CAN !!!
  • Pop your hard drive in another PC - by reversing the above process, and connecting the leads to your hard drive.
Now power up the PC with your hard drive in it and click the following...
  • Start ( bottom left hand corner of your screen )
  • My Computer ( opens up the panel of drives on the PC )
  • Right Click the Hard Drive you slaved to the PC
  • ( you may want to check this is actually your drive, it will most likely show up as D - Drive or some other letter of the alphabet, and the main hard drive will show up as C ( easiest way to tell them apart is the icons are the same, one will be Labeled C and yours will be labeled D or some other letter.
  • When you are 200% sure this is your drive, right click on it and go down to FORMAT - this will wipe the entire drive clean - so double check this is the drive you want to format, you only get one shot at this, once it's gone, it's pretty much gone forever.
  • The format will take a reasonable amount of time, depending on what is on the drive ( how much space has been used ) but simply let the format run until it says completed.
  • Power down the PC, remove the hard drive - reset the pins from slave back to normal - and pop it back in your PC.
There are other ways of doing this, but i feel this is the most painless way.
If you find this helps, please take the time to rate the solution, thank you.
Was this helpful?
Yes
No
Popular Solutions for Quantum 13Gb FIREBALL CX 3.5"
Questions and Unsolved Problems for Quantum 13Gb FIREBALL CX 3.5"
Do you recommend Quantum 13Gb FIREBALL CX 3.5" IDE HD p/n CX13A011 13 GB Hard Drive?
Answer
Answer
Hi. I am trying to upgrade from Windows 98 to 2000. Sadly, Windows 2000 will not recognise the hard... (More)
Answer
I am setting up a new pc with a primary hard drive on a SATA cable.  I would also like to use... (More)
Answer
hi! i have a quantum fireball scsi drive and i try to load windows nt 4.0 on it. i start the setup... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Quantum 13Gb FIREBALL CX 3.5"...:
Top Hard Drive Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Hard Drive Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
