Green picture, adjusting the color controls doesn't help. Everything else OK. Help?
  • 1 more comment
  • Anonymous Mar 29, 2008
    Green screen and picture. Unable to adjust. Everything else is good.
  • Anonymous Jul 06, 2008
    the screen looks green.
  • collectiques Dec 29, 2008
    I too Have the 27U-S60 model with a slightly green tinge in the picture. Notably the problem started immediately when I fired-up the set after a little old lady had the TV which was not in use for some time d/t being blind. I would like a set of schamatics for I have some technical experience as a licenses amatuer radio technician/operator. If I can isolate which transistor it is, I feel I can replace it without any problem. Please assist with schamatics and/or voltage charts, etc. e-mail me at: collectiques4u@hotmail.com.
    Brigadier General:
  • 6,966 Answers
Most problems of this nature indicate trouble with the color driver.
Most TVs have three (3) color drives for red, blue and green. it would appear that your particular unit developed a fault with the green drive. Normally these are transistors (but there are IC versions). Further, they are often on a squarish small PCB right at the rear of the neck of the CRT. Often also, they are with a heatsink.
Corrective measure would require replacement. Doing this would require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable doing this, you may then need the services of a professional TV technician.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 04, 2008
The 1.5k resistor in the load circuit of the green output transistor is open. This is on a small pc board plugged into the CRT. -- Al
Posted on Feb 10, 2008
I have a Panasonic pt-61lcx65 and everything works fine but in the picture there a outline of green and shades of green on the picture, and I've tried everything to get to the service mode to adjust the...
I own the same set in the 44" version. These often need a "prom flash" with the panasonic programming jig to correct for color spots" in the picture. Mine did, over 3 years ago and has bee ok since.
Apr 30, 2014 | Televison & Video
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
The pictures are all blurry and all three colors show up on the screen volume and everything else is ok what do i do
you can adjust your screen focus located at the main controll pannel it is labelled as focus adjustment..if this not work replace the CRT socket of the 3 cathodes the red,green and blue
May 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
My color seems to be more green than should be and I have tried to reset the color with no help
You have a focus/screen control box Find it and adjust the R/G/B screen drives When you first start Go to Menu turn Color off then with a mirror adjust the picture as close as you can to a black and white picture R/G/B screen drives, the little control box you are looking for will have 3 controls on top for focus and 3 controls under them for screen drives to each tube red,green,blue after you have adjusted to a black and white picture then go back and turn color on.
Nov 30, 2009 | Akai PT4298HD Rear Projection Television
Ok i changed the hole board and i have a picture but all the colors are not lined up so i tryed to do the adjustment in the convergence and it will no let me any help please
How bad is the convergence problem? The red and green are the adjustable, but if its the green that is way out, it could be a resistor.
Mar 07, 2009 | JVC AV-48WP74 48" Rear Projection...
Sony KP-511HW40 fleshing with green color and shuts off
this is a common fault adjust the little black box in front behind the small wooden cover. you will see 6 controls don't adjust any of the top 3 only the bottom knobs 1 for each color. slowly back the control counterclockwise turn the set on and wait untill it shows a picture, slowly adjust the control for the color in question utill the color balance is correct- black and white with the color setting turned down all the way with the user menu when balance is ok you are all set.. turn the color back up with user control. rtepeat process if needed.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Televison & Video Logo
351 people viewed this question
Top Televison & Video Experts
Electro Med Services...
