Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips 9P6034C103 - Urgent Response Appreciated
Had tv about 7 yrs, past month or so had hour glass effect when turned on, went back to normal after tv warmed up for several minutes. Now there is no picture when turned on but still has sound - I noticed several different responses for possible solution," main voltage regulator, hv section regulator, deflection circuit such as capacitor, resistor, or transistor. Can someone help me out. Thanks!
  • Philips Master
  • 8,617 Answers
Was the hour glass upright or sideways? From what you described I would say you have a pin-cushion problem. Let me know if you need any additional info.
Posted on Feb 03, 2008
HLT5055WX/XAA turns on then turns off. About 2000 hrs on Philips replacement bulb
That is near or past the normal life on the lamp---2,000 hours or 2 years is normal---I would remove and look at the lamp---if shattered you know and also look the pillar of glass inside the lamp is not bent or warped etc.
Dec 06, 2012 | Samsung HLT5055S 50" TV
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Hourglass Shape
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Feb 17, 2009 | Philips 60PP9202 60" Rear Projection...
NO PICTURE HAS SOUND
I had the same problem. Check www.magnavoxhelp.com for instructions on how to fix it.
Jun 23, 2008 | Philips Magnavox 51MP392H Rear Projection...
Regarding service manual for philips magnavox
You can also get a Factory Service manuals from www.magnavoxhelp.com. The manuals can be downloaded instantly. They are complete with over 2000 pages in all.
Their manuals cover all projection TV models with Chasis # PTV835, PTV836, PTV840, PTV841, PTV842,PTV843, PTV844, PTV847,PTV853
Feb 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
My 60" Philips Magnavox, model 9P6034C103, chassis PTV835
It could be the flyback losing resistace in its windings. What is the chassis number I should have the service manual for it. Phillips/magnavox is hard to cross reference without the actual chassis number.
Feb 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
When you say small do you mean shrunk up top and bottom as well as from side to side. You definitely have a deflection problem either horizontal or vertical.If the picture just shrunk top and bottom you have a vertical deflection problem. Do you have the service manual for your model? If not let me know and I will email you one. Describe the shrinking issue a little more and I should be able to give you some guidance.
Feb 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung HDTV Oval rainbow of colors covering entire screen
I HAVE PANASONIC MODEL TH50PE700U WATCHING IT AND THE COLOR WENT YO B/W
Oct 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Screen now has 3 small boxes in middle - one red, one green, one white
Its easy to fix and cheap. Check www.magnavoxhelp.com for chip kits.
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
