My monitor (viewsonic VA720) is showing "no signal". I've connected reconnected the hard drive is working fine, but its the monitor. Someone told me I may need to buy another wire because maybe the pins are not working, but I can't disconnect the wire from the computer because it's built in. If that's the problem, how do I replace the wire?
Some Laptops or PCs will only work with a 2nd Screen or monitor option on LCD, :Projectors or TV screens.
On Display/.settings/ on PC you can select 2nd monitor option and apply.
U should see your LCD screen flicker and displays your PC 2nd screen
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
