Lost my computer, and now i cannot restore the printer zmodel lexmark
Need to restore my printer, it turns on and is ready to work, but cannot connect to computer.
  • suzanne370 Feb 04, 2008
    thank you
  • Paul Teichmann May 11, 2010
    I doubt I can help you, but you'll have to give more information. Name and model of the printer, operating system on your computer for starters.
    Sniper:
  • 71 Answers
Some printers (USB) need to have the printer driver installed before being connected to the computer.
I would go to the manufacturers website, click on support/drivers, download and instal it as per instructions.
Posted on Feb 04, 2008
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
My lexmark x5650es printer was printing moved printer an computer know printer won't print need help lost
if you are using the same computer and the same cables double check the connection, turn off the computer and the printer.
and then
1. Turn on the printer
2. Turn on the computer
Aug 11, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
PLEASE HELP ME DOWNLOAD MY PRINTER TO MY COMPUTER
get it from here - www.lexmark.com and open the download or drivers / software section and use the driver finder to find your printer and download the software for it.
Sep 11, 2009 | Lexmark X5470 All-In-One InkJet Printer
All in one printer x1270 lexmark
The "All-In-One Center" program is corrupted. I've also had this problem.
You have to download and reinstall the program from here.
Just select your OS (Windows XP) and click download.
*Note: here's the mistake people make a lot. Unplug the printer cable from the computer before opening the program. THEN when the installer TELLS you to connect the printer, do so.
Jul 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
How to install printer without cd installer printer is Z1300
I LOST MY DISK TO INSTALL MY LEXMARK Z1300 PRINTER WHAT CAN I DO
Apr 08, 2008 | Lexmark Z1300 InkJet Photo Printer
How to connect printer to new computer without disc.windows xp
i lost my disc to install my printer i have a lexmark z25
help
Apr 07, 2008 | Lexmark JetPrinter Z25 InkJet Color...
LEXMARK 3100 SERIES NO LONGER APPEARS UNDER PROGRAMS??
HI!
Happy new year to you too.
Please select the printer model number download the driver and install it on your computer please follow the onscreen instructions from the link below.
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=LEXMARK+3100+SERIES&req=:::-1::
If you need further help please get back to me
Regards
Mohammed.
Dec 29, 2007 | Computers & Internet
50 people viewed this question
jasbo
jasbo
