Question about Canon EOS-AE-1 35mm SLR Camera
When we advance film, it takes a picture
When we try to advance the film in our Canon AE-1, it automatically takes a picture. The shutter button doesn't seem to work because the camera takes a picture before we push the shutter button. PLEASE HELP!
  • Sharbear Feb 04, 2008
    I think I should be able to fix it if you just tell me how. Thank you so much!
  • josiah32000 Jun 11, 2008
    i "cleaned" it with lighter fluid cocked it, but it won't take a picture :(
  • 667 Answers
The problem is usually caused by a dirty release magnet. I can tell you how to fix it if you are handy with small tools
Posted on Feb 04, 2008
  • Kevin Pettit
    Kevin Pettit Feb 05, 2008
    Okay, for starters, here is a site that you can download the AE-1 repair manual. Canon FD
    What you need to do is remove the bottom cover, 2 screws
    Locate the magnet toward the rewind side of the camera. It should have a large lever going into it and has a plastic cover.
    I have always used an exacto knife to cut the plastic at the edge of two sides so the cover can be bent up temporarily the gain access to the magnet and magnet arm surfaces.
    Using lighter fluid and Q-tips to clean both faces of the magnet and the arm plate. Canned air or compressed air work to blow out the area
    You can test the camera with the cover off and the magnet exposed. If the magnet holds after you cock the shutter, test fire it and repeat a couple of times, bent the plastic back down and secure it with a glue like Plyobond or a bit of cloth tape.
    If it doesn't hold, clean the magnet again.
2 Suggested Answers
  • 571 Answers
SOURCE: I have an Canon AE-1 and the film advance lever
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Posted on Dec 05, 2009
My Canon AE-1 Program will take a picture when cocking back the film advance lever, the shutter button does not have a roll in my camera what so ever.
Sounds as if the interlock between film advance and shutter mechanism may need looking at. Repair shop job, I'm afraid.
Dec 30, 2015 | Canon Photography
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
Where is the shutter release button on a Canon AE-1? I am trying to load film in the camera, and the shutter crank "thing" is stuck. do i need to release it with a press of a button???
Did you actually mean shutter release or shutter advance? And to load the film,you need to pull the roll winder upwards. While you pull the winder upwards, it would have a tuck voice and then the back cover would open up. Make sure you have wound the entire roll before you open the back.
Jan 23, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AT-1 (Similar AE-1) Shutter Fires Upon Advancing Film Lever
No need to look at the schematics. It only will give you a little headache. Replace Shutter release magnet (MG#3). While winding stage the Mg#3 suppose to catch the lever and any dirt or particle may prevent it. Clean it and it shoud take care of the problem. Good Luck -James. For further assistance email, go to www.camerarepairjapan.com
Dec 20, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
164 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
