Question about Kenmore 82822 Electric Dryer
He3-false lint screen warning.
Hi,   The lights come on and we get a check lint screen warning. Have cleaned the screen and tubing all the way to the external vent.  Doesn't help.  Same warning and no response from the start button.  Do you have any advice on this? Thanks
  • rdunk45 Feb 03, 2008
    I took the whole assembly out, vacuumed everything and checked the connections for the sensor. Looks like the problem lies elsewhere. When the lights come on, only a few of the cycle buttons do anything. For instance, the timed cycle and regular cycle buttons will turn on some lights (including the lint sensor light). Most of the other buttons don't get any response.
    I don't know much about testing dryer circuits. Is there an obvious circuit panel on the back. Is it generally a matter of changing out a single circuit board?
    Master:
    Sergeant:
  • 440 Answers
Try to get in with big vac slim hose to get down in lint area sensor mustr be milted on it down in ther were u take it out to empty
Posted on Feb 03, 2008
  • Anonymous Feb 03, 2008
    ok then i would cheak out back pnael cicuits proably need new back controller panel
    well it mnmight be but u nee dto test them have serv manaul with u best to get a guy out ther if u dont know for sure
6ya staff
SOURCE:
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
Dryer is working but will beep while running and continue to run. I clean lint trap after every load and have checked it.
underneath the lint trap there is a senor, you will need to clean all the lint out inside the dryer and the vent tube:
http://www.applianceaid.com/wpdryer_how-to.html
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Sears HE3 Dryer - "Check Lint Screen" light is on. I cleaned lint screen and area around screen but light will not extinguish and dryer will not turn on. I unplugged dryer for a time and plugged back in...
I am not familiar with your dryer, but it sounds like a safety mechanism where if your lint screen is not cleaned the dryer will not turn on. That "Check Lint Screen" light for your dryer may be connected to a sensor near the lint screen area. Check that out and see if that is the problem. If there is a sensor it could be faulty,
Apr 28, 2010 | Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore he3 model 11082822102 the check lint
remove back panal and clean hose to sensor.
Nov 19, 2009 | Kitchen Ranges
No heat
take off the back of the dryer you will see wires to the lint tube thats heating elements take the removeable plate off and see if its clogged with lint if so clean it out that should fix it if its not elements are probably bad. its also easy fix
Oct 17, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Lint Filter Light comes on and cycle is interupted
Depending on how old this is or how much it is used depends how much lint has built up inside
the air flow tube. I have seen where you look inside where the lint screen is and beneath it with screen removed there is nothing but lint, in which case the dryer thinks the screen is clogged. You might have two screws on the inside of the drum that hold the screen holder in place. First remove the lint screen
and hold the little door that closes when you remove the screen, open the little door and look down inside it with a flash light, if you see a lot of lint, like I said you might be able to remove the holder
and clean this area out, also take a coat hanger and bend a little piece at the end and use this to get most of the lint out of this area and the tube that Leeds down from this area. If this can be done
and you get this area clean and it still happens, you might have to clean the entire area the tube
and the back tube,the tube leeding to the outside of the house and vent. Any questions please post back.
Mar 27, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 82822 Electric Dryer Logo
263 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
